No sound from my tweeter
bored184
A while back I posted about a set of RTA 12s with the peerless tweeters for sale. I ended up contacting the seller a week and a half later while I was at the Bass Pro. He still had them so I went ahead checked them out. Cosmetically they were in pretty good condition other then a thick coating of dirt and grime on the crossover. However one driver was frozen and a tweeter wasn't working. This is probably why he still had them. I still bought them, albeit at a reduced price figuring it would be an easy fix. I checked the tweeter with an ohm meter and got an open reading. I ended up picking up a used peerless tweeter and installed it tonight. The problem is I am still not getting any sound from it. I checked the leads going to the tweeter with my multimeter and I get an ohm reading so I know there is a compete circuit. I also checked the fuse and its still good. Thanks to VR3 I have the parts to work on the crossover but I was hoping to here them stock for a short time before I got into the cross over during my spring break. Any ideas?
Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Amplifiers: ]Ashly FTX 2001 III, Dynaco ST-70, DIY F6
Pre: Adcom GFP 750, Aikido Tube Pre
Post edited by bored184 on
Just because you have continuity in any electrical/electronic circuit doesn't mean you have a complete circuit. I'm not sure what the range is, so I won't comment on that.
My guess would be that what ever opened the tweeter up took out other crossover parts and that you will need to replace them to make it work again.Absolute corruption empowers absolutely.
Lg 55LW5600 TV
Onkyo PR-SC 5508
Legacy Audio Focus SE
Legacy Audio Silverscreen HD center
Polk F/X500i Rears
Parasound HCA-3500
Sunfire Grand Cinema
Behringer iNUKE NU6000DSP
Pair of CraigSUB SS-18.1 -
Check for a open poly switch my money is there. If it is open you can jump it and the tweeted will work once again.Absolute corruption empowers absolutely.
Lg 55LW5600 TV
Onkyo PR-SC 5508
Polk F/X500i Rears
Parasound HCA-3500
Did you check the "new" used tweeter? Did you test the fuse in the holder or out? If out, clean the fuse holder terminals, then try again. If all of that checks out, you have an issue on the crossover board.Political Correctness'.........defined
President of Club Polk -
He has a fuse, no polyswitch.Political Correctness'.........defined
Tweeter is dead, but you already know that.I checked the tweeter with an ohm meter and got an open reading.
Don't use an ohmmeter. Set the multimeter to volts, look for signal on those tweeter wires while playing music or test signals.I checked the leads going to the tweeter with my multimeter and I get an ohm reading so I know there is a compete circuit. -
Thanks for your input! The new to me but used tweeter measured 7.6ohms. Fuse checked out fine and cleaned the terminals, still no sound. I guess I will be working on the crossover tonight, I have never done it but should be fun :cheesygrin:.Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Pre: Adcom GFP 750, Aikido Tube Pre -
Good news, the tweeter looks good! Now check for the small round blue poly switch on the crossover, just jump it and you should have music!
Attachment not found.Make it simple...Make it better! -
F1 the prints I looked up for his showed a poly which is why I said to look for it. From what I have read and seen some did and some did not.Absolute corruption empowers absolutely.
Lg 55LW5600 TV
Onkyo PR-SC 5508
Polk F/X500i Rears
Parasound HCA-3500
I wish it was as simple as the polyswitch. Mine is an older set which has the fuse, the fuse and tweeter check out so by reason of dudection it must be in the cross over. As far as I know of there isnt anything else.Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Why not swap the tweeters and see if the problem follows the tweeter you suspect is bad?
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
^^^^^ding ding ding.....+22-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
The various schematics for the RTA-12 show three Mylar or Electrolytic Capacitors in Series with the Tweeter. There are also, most likely, a few small Silver Mica bypass caps as well. If there are indeed Electrolytics in the circuit, they are most likely the culprit.I wish it was as simple as the polyswitch. Mine is an older set which has the fuse, the fuse and tweeter check out so by reason of dudection it must be in the cross over. As far as I know of there isnt anything else.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Did they ever use silver solder on the old RTAs? Ive got a rat shack desoldering iron that wont even melt the solder. Ive attemtped this on the board and the driver thats shirfted. Ive been in discussion with Vr3 and tried mutiple ways to melt this stuff, still no luck.Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
The heat from the iron is dissipated too quickly by the copper traces and the board itself. You'll need a higher wattage soldering iron, and a de-soldering pump, which is what I use. Rat Shack sells a 50 watt adjustable soldering iron, and the solder pump. Set the iron to about 35 watts, and you should be fine. Don't set the iron to high/hot, or you'll end up burning the flux.Did they ever use silver solder on the old RTAs? Ive got a rat shack desoldering iron that wont even melt the solder. Ive attemtped this on the board and the driver thats shirfted. Ive been in discussion with Vr3 and tried mutiple ways to melt this stuff, still no luck.Home Theater/2 Channel:
Here is what I have:
Desoldeing: http://www.radioshack.com/product/index.jsp?productId=2062731&filterName=Type&filterValue=Desoldering
Soldering: http://www.amazon.com/Weller-WLC100-40-Watt-Soldering-Station/dp/B000AS28UCSpeakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
I never liked the bulb type solder sucker, whether attached to the iron's tip or hand held. I use the spring loaded pump type. The 40 watt Weller should do the job, but see if they have a flat/blade tip to heat up more surface area.Here is what I have:
Soldering: http://www.amazon.com/Weller-WLC100-40-Watt-Soldering-Station/dp/B000AS28UCHome Theater/2 Channel:
How about some solder-wick? As long as the iron gets hot enough, you should be able to soak up the solder without "sucking up" any trace.Yamaha RX-A2050 AVR (5.0.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets
Wicks are great for removing large amounts of solder, but there still may be solder in the through-hole, which is where the solder pump comes into play. The traces on the Polk crossovers are pretty thick, so I wouldn't wory about damaging them with a pump.How about some solder-wick? As long as the iron gets hot enough, you should be able to soak up the solder without "sucking up" any trace.Home Theater/2 Channel:
I was able to use my soldering iron and wick to get a majority of the solder off the board. There is still a thin layer of solder around the holes. Do I need to worry about getting all the old solder off or is there a point when it doesnt matter?Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Trial and error! Works all the time!Why not swap the tweeters and see if the problem follows the tweeter you suspect is bad?SRT Seismic System with dual PSW1200's
RT5000 x 2
RT2000p
CS400i
CS350-LS
LS F/X
PSW650
PSW1000 w/Dayton SPA1000
DSW MicroPro 4000
Adcom amps
Pioneer Elite SC-89
Pioneer PLX-1000 Turntable
PS4
XBOX One
MIT Interconnects
BJC -
Why not swap the tweeters and see if the problem follows the tweeter you suspect is bad?chefkungfu wrote: »Trial and error! Works all the time!
I thought of that but I ended up checking the tweeter with an ohm meter. Since the meter read open I figured the tweeter was fried.
The odd thing though is that I put the new tweeter in, it to did not work. I knew it was good because I got an ohm reading of 7.6. What ever fried the tweeter also fried something in the crossoverSpeakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Not unless the solder has some sort of visible contaminant in it; in the end, it all conducts.Yamaha RX-A2050 AVR (5.0.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets -
That's kind of odd, I hope you narrow down the problem! Can you see any visual damage to the xo? Any dark spots?
Just trying to figure out what went wrong.
I had to de-solder some resistors on an amp, there was some "burnt" resistors on mine. Logged on to parts-express, bought the parts and off to work I went on them. Still holding strong to this day, although I remove the amp periodically and give it a once over to make sure it still looks good.
Good luck with yours!I thought of that but I ended up checking the tweeter with an ohm meter. Since the meter read open I figured the tweeter was fried.
The odd thing though is that I put the new tweeter in, it to did not work. I knew it was good because I got an ohm reading of 7.6. What ever fried the tweeter also fried something in the crossoverSRT Seismic System with dual PSW1200's
RT5000 x 2
RT2000p
CS400i
CS350-LS
LS F/X
PSW650
DSW MicroPro 4000
Adcom amps
Pioneer Elite SC-89
PS4
XBOX One
MIT Interconnects
BJC
