LSi7 Right Speaker Underpowered and making popping noises
cyboman
cyboman Posts: 4
edited March 2013 in Troubleshooting
Hi all,
I purchased a pair of LSi7 bookshelf speakers and they've worked great for a few months.
I recently picked up a Onkyo TX-NR515 receiver and after rewiring everything I've noticed that my right speaker is now very underpowered when compared to the left is also very tinny sounding and making popping noises.
I plugged it into the left channel on the receiver and it's still doing the same thing. I tried use different wire, but still getting the same problem.
Not sure if there is something I'm doing wrong, but I can't imagine that the speaker is blown being that I've never 'blasted' them. Hoping there is something obvious that I'm not thinking about. Any suggestions would be appreciated.
Thank you.
Post edited by cyboman on
  • rpf65
    rpf65 Posts: 2,127
    edited March 2013
    I think you may be over stressing you avr. The LSI series speakers are 4 ohm speakers, while the LSIM are the 8 ohm series. According to Onkyo your avr isn't designed got 4 ohm speakers.
  • cyboman
    cyboman Posts: 4
    edited March 2013
    Damn. Anything I can do other than buying a new receiver? Is it possible that I ruined the speaker?
  • eclypse
    eclypse Posts: 595
    edited March 2013
    Just swap the speakers and see if the one sounds the same on the other side.
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
  • cyboman
    cyboman Posts: 4
    edited March 2013
    I did swap them and it does sound the same..
  • eclypse
    eclypse Posts: 595
    edited March 2013
    Also he should be able to grab a new amp to power those speakers like a Emotiva XPA-2,3 or 5 as long as the receiver he has now has pre-outs. Those would drive 4 ohm speakers.
    http://shop.emotiva.com/collections/amplifiers
    Find a good used one to save some dough as long as it still has the warranty. Theres some on ebay.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • eclypse
    eclypse Posts: 595
    edited March 2013
    cyboman wrote: »
    The same speaker produces that noise or the same channel?
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • eclypse
    eclypse Posts: 595
    edited March 2013
    Tried the one speaker alone? If its still doing it alone then i'd say the speaker is now bad. Wait for a better opinion though...
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • eclypse
    eclypse Posts: 595
    edited March 2013
    There is a guy selling a pair of LSi7s cheap in this forum http://www.polkaudio.com/forums/showthread.php?146948-Polk-LSI-7-s-and-Matching-LSIC if it comes down to replacing the speaker/parts.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • cyboman
    cyboman Posts: 4
    edited March 2013
    Can I run an amp through the receiver through a subwoofer pre-out? There are two on the back of this receiver.
  • rpf65
    rpf65 Posts: 2,127
    edited March 2013
    No, you can not use the sub out as a pre out. Your AVR has no pre outs. If you continue to run 4 ohm speakers on equipment designe for higher impedance speakers, on of 3 things will happen:
    1) you destroy speakers and/or cross overs
    2) you do serious damage to your AVR amp section-usually terminal
    3) Both 1 and 2
    F1nut Posts: 51,822
    edited March 2013
    What were you using for power before buying the AVR?
