Grr, CSi5 crossover parts
Inspector 24
Inspector 24 Posts: 1,308
edited April 2013 in Troubleshooting
Grabbed a CSi5 for $50, tweeter worked when I demo'd, didn't when I got home. Found the 5w2ohm ceramic resistor a bit burned and cracked, also the 10uF 50V cap next to it bulging.
RadioShack was useless, and internet searching hasn't been much better finding a resistor, caps seem easy to find.
So my question, where can I go to buy the parts?
Alternatively, how much is a new crossover right from polk?
TIA!
Ryan
Up
LSi15 LSiC - RX-V3000
Down
Sim2 D60 - Dragonfly 106" Panny 500
Post edited by Inspector 24 on
    F1nut Posts: 52,011
    edited March 2013
    If you want to replace with like parts look at Parts Express, Mouser or Digikey. If you want upgraded parts look at Sonic Craft.
  • Inspector 24
    edited March 2013
    Thanks for the suggestions. I searched around those sites for a while but having some trouble finding the right resistor. Caps seem easy enough, but all the resistors are inline types, with the leads coming out either end. I need a tower style if you will, where the leads are on the same end:
    Any idea where I can find one of those?
    Up
    Down
  • Inspector 24
    edited April 2013
    Bump.
    Up
    Down
    F1nut Posts: 52,011
    edited April 2013
    Just bend the leads of an inline resistor under it to fit the holes.
  • Inspector 24
    edited April 2013
    Got it! Thanks!
    Up
    Down
