psw505 frequency response
fireshoes
Can someone plot this for me? I forgot I don't have excel! :eek:
These are the uncorrected numbers, so you should use pjdami's corrected graph. If you don't have it, I can email it.
Frequency SPL 79.4 75 75 78 70.8 72 66.8 71.5 63.1 74.5 59.6 74.5 56.2 74.5 53.1 79 50.1 80 47.3 80 44.7 78 42.2 77 39.8 76.5 37.6 76 35.5 76 33.5 77 31.6 78.5 29.9 75.5 28.2 72 26.6 72.5 25.1 73 23.7 71 22.4 67 21.1 60.5 20 56Thanks!
Post edited by fireshoes on
yeah. that looks pretty good there fireshoes. I'm thinking maybe the sub is 4 to 5 db too "hot" from the overall gain from 55 hz down but I could be wrong.
Nice extension from a Polk sub.
Paul -
Sounds like I've got some tweeking to do still. I sorta forgot about the speakers still playing some below 80hz. I'll chart up to 100hz and see what's happening there too.
Yeah. That's a good thing to do to see the transition from the mains to the sub. But still looks pretty good. No huge peaks or nulls that some are plagued by. You can definitely tweak that to your liking some more. Try flipping the phase switch on the sub on a sweep and see what that does from 100 - 50 hz (assuming you are crossovered at 80 hz).
Looks promising for the LSi W for sure.
Thanks for sharing your sub's mugshot.
Paul -
I actually ran tones for two locations with 0º and 180º phase at each spot. This is 180º on the second spot, which I thought had the best curve. It actually looks good where it's at too. Just inside my left main, with both pointed towards the sweet spot.
Very good extension - solid to 25 Hz with room gain included - nice. Goes deep enough for most movies. Overall a decent looking curve too."What we do in life echoes in eternity"
SVS
