AVR Settings
ScottyDugs
ScottyDugs Posts: 91
edited March 2013 in Speakers
Whats the difference?...dynamic compression(under surround parameter) VS dynamic volume(under audyssey)?
Also, low frequency effects(under surround parameter which mine is set to 0dB) VS subwoofer level(mine is set to +4.0dB)?
My SETUP
AVR: Denon 1913
Main L/R: Polk LS90's
Center: Polk CS350LS
Side Surrounds: Polk LS/FX's
Rear Surrounds: Polk RT/FX's
Subwoofer: Polk PSW300
100% Cinematic Adventures, 0% Music
  • ScottyDugs
    edited March 2013
    anybody?
    My SETUP
    AVR: Denon 1913
  • amgala
    amgala Posts: 111
    edited March 2013
    Scotty, it would benefit you to go through the Audyssey 101 thread on AVSforum.com:
    http://www.avsforum.com/t/795421/official-audyssey-thread-faq-in-post-1/51750#post_21782993
    It will answer most if not all of your questions and it is very easy to understand.
    Front Speakers: Polk Audio LSi15 x 2
    Center Speaker: Polk Audio LSiC
    Rear Speakers: Polk Audio LSiF/X x 2
    Subwoofers: Polk Audio PSW505 x 2
    AVR: Denon AVR-3313CI
    Amp: Emotiva XPA-5
  • ScottyDugs
    edited March 2013
    My SETUP
    AVR: Denon 1913
  • amgala
    amgala Posts: 111
    edited March 2013
    You're welcome! And if you have any other questions, there is an on-going thread on the XX13 series Denon receivers on AVSForum also. I have a 3313 so I check out that forum a lot. They are very helpful!
    http://www.avsforum.com/t/1409431/the-official-denon-avr-xx13-model-owners-thread-faq
    Amp: Emotiva XPA-5
