AVR Settings
ScottyDugs
Whats the difference?...dynamic compression(under surround parameter) VS dynamic volume(under audyssey)?
Also, low frequency effects(under surround parameter which mine is set to 0dB) VS subwoofer level(mine is set to +4.0dB)?
My SETUP
AVR: Denon 1913
Main L/R: Polk LS90's
Center: Polk CS350LS
Side Surrounds: Polk LS/FX's
Rear Surrounds: Polk RT/FX's
Subwoofer: Polk PSW300
100% Cinematic Adventures, 0% Music
AVR: Denon 1913
anybody?My SETUP
AVR: Denon 1913
100% Cinematic Adventures, 0% Music -
Scotty, it would benefit you to go through the Audyssey 101 thread on AVSforum.com:
http://www.avsforum.com/t/795421/official-audyssey-thread-faq-in-post-1/51750#post_21782993
It will answer most if not all of your questions and it is very easy to understand.Front Speakers: Polk Audio LSi15 x 2
Center Speaker: Polk Audio LSiC
Rear Speakers: Polk Audio LSiF/X x 2
Subwoofers: Polk Audio PSW505 x 2
AVR: Denon AVR-3313CI
Amp: Emotiva XPA-5 -
ThanksMy SETUP
AVR: Denon 1913
You're welcome! And if you have any other questions, there is an on-going thread on the XX13 series Denon receivers on AVSForum also. I have a 3313 so I check out that forum a lot. They are very helpful!
http://www.avsforum.com/t/1409431/the-official-denon-avr-xx13-model-owners-thread-faqFront Speakers: Polk Audio LSi15 x 2
Amp: Emotiva XPA-5
