how do Polk SDA 1B compare to SDA 2B?
  • Schurkey
    Schurkey Posts: 2,122
    edited March 2013
    heiney9 wrote: »
    There are 2A's that have side by side tweeters.
    I can find no evidence of this. My downloaded copy of The Handbook specifically states that 2As have a single tweeter, confirmed by the list of drivers which shows only one tweeter.
    Can you list your source for 2As with side-by-side tweeters? If not, I think we can put this to bed.
    heiney9 Posts: 25,430
    edited March 2013
    My list of drivers clearly states 2 - sl2000 tweets for the 2A. The sentence on page 7 is a bit confusing. After reading the paragraph over a couple times it does seem to indicate a single tweeter. My copy must have a typo when it lists the drivers for the 2A's, which was subsequently corrected in the dl version.
    So yes, lets' put this to bed because who cares, if he has a single tweeter, then he has a single tweeter. I do know of 2A's which were early runs having 2 tweeters, perhaps they were mis-identified. We ALL know Polk and transitional models can be hard to classify. That's the best evidence you're going to get, unless it comes from Communist China.
    edited March 2013
    Here is a photo of the 3rd generation driver list from the Final SDA Compendium.
  • Mr. Bubbles
    Mr. Bubbles Posts: 736
    edited March 2013
    heiney9 wrote: »
    The third paragraph of you post is incorrect as to how the SDA works in multiple driver SDA's. You can search for the proper explanation as I and others have posted about it before.
    Can you please point me to where I can find this information you mention here? I have never been too good with the search function here. If you can just direct me to links of some of the information. I have always been under the understanding that the sda works the same in all vintage sda models regardless of # of dimensional drivers, and my studies of the schematics have verified this idea. If this is incorrect I would like to understand how and why and learn more about the subject that I may not already understand.
    So far my understanding is that the dimensional drivers play a signal that is equal to the Left minus Right (or r-l) signal. Essentially only those portions of the signal that is different between the left and right channels. I have understood this principal to be the same in all models with the only differences being the # of drivers (of which all play the same signal in the dimensional circuit) and the wiring of this circuit in TL-able models vs earlier versions. As mentioned earlier, I do understand the progressive point source design in the multi tweeter models, but this is not associated with the dimensional circuits. I would like to learn more about this if I have been incorrect in my understanding.
    Thanks again.
  • westmassguy
    westmassguy Posts: 6,850
    edited March 2013
    heiney9 wrote: »
    And here's a photo of the 3rd generation from my downloaded handbook. It appears we're both right Heiney9
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Mr. Bubbles
    edited March 2013
    heiney9 wrote: »
    I have never seen that information until now. All 2A's i have seen or heard of were the single tweeter variety. i would love to see one of the compendiums some time. The different 2A models are not listed in the transitional list in the stickey. But I have also seen other oddballs pop up that had no other background info to describe them either. There were a lot of prototypes and transnationals back then. Though I have never heard any of the models with dimensional tweets I don't believe I would enjoy them. Similar to previously mentioned reasons along with the terrible lobing that must accompany those as well. My ears don't even tend to like the Monitor 10's and such with the side by side mids running the same signal.
  • Mr. Bubbles
    edited March 2013
    is there somewhere I may be able to download the information from the sources pictured from you two guys?
  • westmassguy
    edited March 2013
    http://vr3mods.com/uploads/SDA_Handbook_2011_Rev2.pdf
  • Mr. Bubbles
    edited March 2013
    I think Polkieman may have posted a link to one of those in another thread but it doesn't appear to be the one H-9 has. Where may I find that one, and is the link to the one in the other thread the same as the one Westmassguy has here? here is the link...
  • westmassguy
    edited March 2013
    I believe Heiney9 has the original, printed, bound version.
  • nspindel
    nspindel Posts: 5,343
    edited March 2013
    Which is now out of print.
  • gdb
    gdb Posts: 6,012
    edited March 2013
    I think that everyone here tends to lose sight of the fact that EVERY SDA model, when it was introduced and offered for sale to the audio public.........was the Cat's A$$ at that moment in time, and the sound was what they wanted it to be ! I'm pretty sure that without the benefit of a hindsight view, any of the SDA models would be regarded as great sounding speakers, absent any others for purposes of comparison. I personally think that the sound/effect from stock 1As is great and I actually wish that my SRS2s sounded a little more like the 1As in the dimensional department.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited March 2013
    He should go make a pdf of it so we can all enjoy it:cheesygrin:
    nspindel wrote: »
  • nspindel
    edited March 2013
    Out of print means out of print, afraid you're out of luck. H9 has it because he paid for it......
  • westmassguy
    edited March 2013
    PolkieMan wrote: »
    It also has errors which have been corrected with the PDF Handbook
  • PolkieMan
    edited April 2013
    Well then, I am quite happy with the PDF Handbook, good stuff, printed out, sheet protected and in a binder :biggrin:
