Dimensions for the PSW505 Powered Subwoofer?
BlackHawk
BlackHawk Posts: 16
edited March 2013 in Speakers
Hi. The dimensions for the PSW505 Powered Subwoofer located at the link below...
http://www.polkaudio.com/products/psw505
Height 16 1/8" (40.96cm)
Width 15 1/8" (38.42cm)
Depth 18 3/16" (46.20cm)
Is the 16 1/8" height stated with or without the 4 little feet/legs/pegs on the bottom? I ask because I have a height situation where this may be placed. Can the pegs/feet be taken off and if so does it have an effect on the sound? Are there any known issues, common problems with this sub? Thank you.
  • BlackHawk
    BlackHawk Posts: 16
    edited March 2013
    bump
  • Tbone289
    Tbone289 Posts: 661
    edited March 2013
    I'll try to remember to measure mine for you when I get home.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • amgala
    amgala Posts: 111
    edited March 2013
    Tbone289 wrote: »
    TMI...
    J/K, I was going to post almost word-for-word the same thing!
    Front Speakers: Polk Audio LSi15 x 2
    Center Speaker: Polk Audio LSiC
    Rear Speakers: Polk Audio LSiF/X x 2
    Subwoofers: Polk Audio PSW505 x 2
    AVR: Denon AVR-3313CI
    Amp: Emotiva XPA-5
  • BlackHawk
    BlackHawk Posts: 16
    edited March 2013
    Tbone289 wrote: »
    That would be great. Thank you very much.
  • BlackHawk
    BlackHawk Posts: 16
    edited March 2013
    Height with and without feet/pegs would be great. Thank you.
  • Tbone289
    Tbone289 Posts: 661
    edited March 2013
    amgala wrote: »
    TMI...
    LOL. I didn't even catch that.
    I'm more familiar with those dimensions than the actual dimensions of my PSW505 though and, if required, I wouldn't have to wait to go home to provide them!
  • Tbone289
    Tbone289 Posts: 661
    edited March 2013
    I measure the height without feet to be 15 3/4"; 16 1/8" with feet. I don't know how the feet are mounted--there are no visible screws. I would guess that the plastic feet just snap into recessed holes in the bottom of the sub.
    There are no issues with the PSW505, and it's a very good HT sub for the price. I would want to use some type of small feet on the bottom. Maybe some shallow stick-on rubber feet or something.
  • BlackHawk
    BlackHawk Posts: 16
    edited March 2013
    Thank you very much Tbone, your help is greatly appreciated!
