5.1 Dolby Digital Digital ProLogic II Speaker Placement
What is the best location for the surrounds in a 5.1 setup? Side or rear?
mine are in the rear....
Depends if they're bipoles, dipoles, or direct... plus distance and height as sides as opposed to as rears... plus personal preference. Bottom line: try it both ways and see what you like. :biggrin:2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
Always best to go with what they use when doing the mix.
http://www.dolby.com/us/en/consumer/setup/connection-guide/home-theater-speaker-guide/index.htmlEquipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
All rooms,and furniture placement is different. It depends what works best in your given room,as well as the type speakers you are running, and a bunch of other things. With a little more info, room size, seating arrangement, distance from back wall,and speaker type you are using, we may be able to offer you more help.
falconcry72 wrote: »Depends if they're bipoles, dipoles, or direct... plus distance and height as sides as opposed to as rears... plus personal preference. Bottom line: try it both ways and see what you like. :biggrin:
I have dipoles at this point. -
Then they go directly in-line with your ears to either side of the listening position so you're sitting in the null between the drivers.I have dipoles at this point.Equipment list:
Emotiva XPA-3 amp
