DCM speakers on CL. Should I check them out?
Saw these on CL and they're not too far from me. I have no experience with DCM but I've read that their early stuff was not bad. I think these may be part of the Timeframe series. Are these worth checking out?
http://longisland.craigslist.org/ele/3686452159.html
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
I would definitely go listen to them if it is not far.
My tf400s are 38 in. tall, and the driver has a square anti difraction grill visible under the sock, not a round driver with a silver ring.
There is a great thread called whatever happened to steve eberbach on avs forums which may be a good resource.humpty dumpty was pushed -
My first speakers were DCM Timewindows from 1977. I liked them a lot back then.
TF's for $75? Hail yeah I would go get them! Look like 400's.--Gary--
For $75 it can't hurt to check them out. Look like TF 350's
