DCM speakers on CL. Should I check them out?
ROHfan
ROHfan Posts: 1,014
edited March 2013 in Speakers
Saw these on CL and they're not too far from me. I have no experience with DCM but I've read that their early stuff was not bad. I think these may be part of the Timeframe series. Are these worth checking out?
http://longisland.craigslist.org/ele/3686452159.html
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
  • scottyboy76
    scottyboy76 Posts: 2,905
    edited March 2013
    I would definitely go listen to them if it is not far.
    My tf400s are 38 in. tall, and the driver has a square anti difraction grill visible under the sock, not a round driver with a silver ring.
    There is a great thread called whatever happened to steve eberbach on avs forums which may be a good resource.
    humpty dumpty was pushed
  • Sprags
    Sprags Posts: 120
    edited March 2013
    My first speakers were DCM Timewindows from 1977. I liked them a lot back then.
  • halo71
    halo71 Posts: 4,642
    edited March 2013
    TF's for $75? Hail yeah I would go get them! Look like 400's.
    --Gary--
  • KLapinas
    KLapinas Posts: 608
    edited March 2013
    For $75 it can't hurt to check them out. Look like TF 350's
