Point to point crossovers?
Toolfan66
Toolfan66 Posts: 18,165
edited March 2013 in DIY, Mods & Tweaks
Anyone see any reason one couldn't use a piece of delrin to build a point to point crossover?
I don't see where delrin has any conductivity that might harm the process..
Post edited by Toolfan66 on
    VR3 Posts: 29,539
    edited March 2013
    Should be safe
    I have used Aluminum -
    edited March 2013
    I plan to drill holes in the delrin to feed the leads into and do my point to point on the bottom side as well as having holes to zip tie the capacitors, and inductors down to the delrin..
  • FTGV
    FTGV Posts: 3,650
    edited March 2013
    Toolfan66 wrote: »
    It's an insulator not a conductor so u r good.
  • zingo
    zingo Posts: 11,258
    edited March 2013
    I've done a point to point crossover on MDF and it worked great.
  • westmassguy
    westmassguy Posts: 6,850
    edited March 2013
    Toolfan66 wrote: »
    As long as it doesn't conduct, you'll be fine. It's an engineered plastic, so be careful with the soldering iron. You can also go "old school", and use 1/8", 3/16", or 1/4" Masonite
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    VR3 Posts: 29,539
    edited March 2013
    Toolfan66 wrote: »
    I would be concerned about it melting...
    May I suggest epoxy glass?
    http://www.digikey.com/product-detail/en/PC8-UNCLAD/PC8-UNCLAD-ND/354452
    I have used this for that purpose before with great results.
    edited March 2013
    I have used it on my binding post cups with good results so I figured I was good but with what I have planed I thought I would ask just in case someone saw some concern.
    I'm not worried about melting, that I can control, and it's not like your there very long with the iron.
    My plan is to use 1/2" and machine a pocket on the bottom side where I will do my point to point. That way I can mount it flush to the cabinet or cap the bottom with another piece of delrin. Leaving the work looking clean on top..
    VR3 Posts: 29,539
    edited March 2013
    1/2"? Sweet!
    As soon as I regain connection with my laptop I am sending the dimensions of the shelf I had in mind...
    I would check out the SDA SRS 2 modification I did Larry, that is similar to what you are planning... Just not a 1/2" thick... That's going to be cool!
    treitz3 Posts: 20,088
    edited March 2013
    Sounds cool. Question for you though.....why delrin, if you don't mind me asking?
    VR3 Posts: 29,539
    edited March 2013
    Delrin is the brand name for an acetal resin engineering plastic invented and sold by DuPont. Often marketed and used as a metal substitute, Delrin is a lightweight, low-friction, and wear-resistant plastic capable of operating in temperatures in excess of 90 degrees celsius (approx 200 degrees Fahrenheit). - WIKI
    It is also insanely pricey.
    edited March 2013
    treitz3 wrote: »
    I have access to it easily.. Also it's easy to machine and it looks great..
    edited March 2013
    Ah, gotcha. If I'm not mistaken, that's the material used in Joe's "THE" record clamp you and I use.
    VR3 Posts: 29,539
    edited March 2013
    Toolfan66 wrote: »
    Hmmm you should make my shelf with it... :-P
    Did you receive the email? I sent it to your paypal email
    edited March 2013
    treitz3 wrote: »
    That's it..
    VR3 wrote: »
    I will look at it..
    VR3 Posts: 29,539
    edited March 2013
    You da man! :)
  • dracoskeeper
    dracoskeeper Posts: 142
    edited March 2013
    Point-2-point crossovers that I did for my brothers 2.3tls. 3/16ths smoked lexan, DH labs Silver Sonic wire, everything pt 2 pt and soldered, no connectors anywhere but the binding posts. I could not believe a speaker this size could disappear! I'm doing mine next when I finish working on others gear!!!
    VR3 Posts: 29,539
    edited March 2013
    This is real similar to the SDA SRS 2 crossover I did - real nice Dracoskeeper!
  • dracoskeeper
    edited March 2013
    Thanks, I follow all of your builds. I'll do a detailed write up when I do mine, I'm doing all of the inductors also but the configuration should be similar. I'm a huge proponent of pt 2 pt crossovers/wiring and eliminating all unnecessary connectors. I can't see the point in using high end speaker cable feeding a speaker then going thru nickel plated brass connectors (37 by my count in the 2.3tl's) and mid grade in-cabinet wiring.
    edited March 2013
    Auditioning for a spot on the View ^^^^^
    edited March 2013
    Those look great!! Now I'm excited even more..
