Bryston BDP1 Digital File Player - number 2
BlueFox
BlueFox Posts: 15,251
edited May 2013 in Going Digital
I just unboxed and hooked up my new BDP1 to my two channel system, and moved the first BDP1 into the HT system. Now I can enjoy music in either room. For the HT system I had to buy a BNC to RCA cable since Bryston only provides two digital outputs; an AES balanced, and a BNC. That is my one complaint I have with this player. RCA SPDIF is by far the most common connection, but it is not supported. To add insult to injury, the Bryston BDA1 DAC has two RCA inputs! But, what the heck, everything is working fine now. I just need to find some other use for my MIT digital cable.
Post edited by BlueFox on
  • FTGV
    FTGV Posts: 3,650
    edited March 2013
    BlueFox wrote: »
    That is my one complaint I have with this player. RCA SPDIF is by far the most common connection, but it is not supported.....I just need to find some other use for my MIT digital cable.
    Thats likely because BNC unlike RCA is a true 75 ohm connector as called for in the SPDIF spec.An impedance mismatch can cause reflections in the cable thus increased jitter.As for the MIT cable you could have also purchaed a simple RCA to BNC adaptor at your local rat shack.
    I wish I had your audio budget.
    SCompRacer Posts: 9,085
    edited March 2013
    FTGV wrote: »
    Starting to see more BNC connectors. Used to be you just saw it mostly on gear that stayed overseas.
  • FTGV
    FTGV Posts: 3,650
    edited March 2013
    It would be nice to see it on every dac or digital source atleast as an option.
  • BlueFox
    edited March 2013
    FTGV wrote: »
    At least then there would be more cable options from the manufacturers. RCA to BNC cables aren't common. I had this issue 4-5 years ago when I wanted to use my Wadia iTransport and Benchmark DAC1 at work. The basic Benchmark only had a BNC input and the Wadia was RCA out. In that case I bought a cheapo custom made cable from Bluejeans, but this time I bought Bryston's cable.
  • Jhayman
    Jhayman Posts: 1,548
    edited March 2013
    Ya gotta love our Canadian Gear..
    A friend if mine has a pr of a KEF 207/2 and running Bryston amps, he commented about the BDP1 he said Bryston should stick to what they know best Amps..
    He much prefers the JRiver system..
    That was his opinion, I would like to hear it though I've always liked Bryston, maybe it's in my budget, lol. Not..
  • BlueFox
    edited March 2013
    Well, now that I listening to music again in the HT room, an old problem has resurfaced. While not apparent with classical, jazz is really causing the problem. The problem is I have a 57" CRT rear projection TV. It still works fine (1080i), so I can not rationalize replacing it. However, the top part is basically a 57" hollow plastic drum, and bass causes it to vibrate. Listening to music with the TV vibrating is not a pleasant experience, so I resurrected my old fix when I first encountered this issue. I have Home Depot adjustable shower curtain rods, two per side and three on top, wedged between the TV and walls/ceiling. This provides extra strength to the cabinet and greatly reduces the vibrations, but they do look like crap.
  • bikerboy
    bikerboy Posts: 1,228
    edited March 2013
    Bnc is better than rca. Too bad it doesn't have I2S out.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • FTGV
    FTGV Posts: 3,650
    edited March 2013
    Humm,J River is a slick piece of software(I,m a user) but the BDP1 is a complete PC/software system optimized strictly for hi performance audio.I have read many glowing reports about it's sound quality.
  • BlueFox
    edited May 2013
    Just a follow up on this digital file player. I absolutely love it. I have so many CDs ripped to the drive now it is impossible to play all of them in my lifetime. Since I started ripping files in Apple Lossless for my iPod/Wadia music server, I have continued using it. On a 500GB hard drive with hundreds of CDs, I still have 318GB left. Since the BDP1 has 4 USB inputs, I can not imagine ever needing more storage.
    I recently upgraded my DAC to the Bryston BDA2, and that has taken this music server to a higher plane. It is amazing how well these two work together. Of course, using a Shunyata digital cable, and Shunyata power cords helps this gear reach its full potential.
    I made a suggestion to Bryston to create a new product that combines the BDP1 and the BDA2 into a single chassis. Basically, it would be like a CD player, but capable of holding thousands of CDs, and also play high-res files. By being in one chassis I could save a couple thousand dollars by not having to buy a digital IC, and second power cord. Plus, it should cost a bit less than two standalone products. With a digital output then an external DAC could be added 4-5 years later if a better DAC is developed.
  • dragon1952
    dragon1952 Posts: 4,907
    edited May 2013
    BlueFox wrote: »
    :eek: We must not shop in the same places...yikes.....like Rodeo Dr vs Baltic Ave :sad:
  • BlueFox
    edited May 2013
    dragon1952 wrote: »
    The Cable Company. http://www.thecableco.com/
    I made a decision a few years ago to get best I can afford at the time because once I retire there will be no more purchases. Of course, since I keep spending my retirement savings, I have to keep working to replace it. :eek:
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited May 2013
    I am kinda starting to think la little along your lines Bluefox, I was pondering the idea of my next addition to the 2 ch rig but thought ' sh$t' I going to have to buy new cables that would cost as much as the component lol
  • BlueFox
    edited May 2013
    PFB, I have become a true cable fanatic. Good cables, and clean power, will bring out so much musical information in gear that it is like a component upgrade. The BDA2 DAC was the first new piece of hardware I had bought in some time. Before I was just upgrading my cables and power, and being completely amazed at what I am hearing.
    I have become a Bryston fan boy for digital, and a Shunyata fan boy for cables. I can not give either company enough praise for what they have done to my modest system.
  • teekay0007
    teekay0007 Posts: 2,289
    edited May 2013
    BlueFox wrote: »
    I have a 57" CRT rear projection TV. ..and bass causes it to vibrate. Listening to music with the TV vibrating is not a pleasant experience, so I resurrected my old fix when I first encountered this issue. I have Home Depot adjustable shower curtain rods, two per side and three on top, wedged between the TV and walls/ceiling. This provides extra strength to the cabinet and greatly reduces the vibrations, but they do look like crap.
    Please post a pic of this fix! Sounds really ghetto. Gotta see it! :lol:
  • BlueFox
    edited May 2013
    teekay0007 wrote: »
    Here you go. Post 20.
    http://www.polkaudio.com/forums/showthread.php?70026-Modifications-for-LSi15-s&highlight=Plastic+drum
    The room looks better now. Not as much acoustic treatment, PSB Synchrony One towers now, better use of the audiophile acoustic vibration reduction rods, and a PSB Synchrony One center.
  • Phasewolf
    Phasewolf Posts: 514
    edited May 2013
    Open the TV up and clean the inside of the plastic shell and apply some damping material to it. No more rattle.
    Absolute corruption empowers absolutely.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Legacy Audio Focus SE
    Legacy Audio Silverscreen HD center
    Polk F/X500i Rears
    Parasound HCA-3500
    Sunfire Grand Cinema
    Behringer iNUKE NU6000DSP
    Pair of CraigSUB SS-18.1
  • BlueFox
    edited May 2013
    Phasewolf wrote: »
    I have to open it up and install a IEC connector so I can replace the hard-wired AC cord with a Shunyata power cable. What is dampening material and where do I get it? I will be surprised if that stops the vibration, but I will try it.
    pitdogg2 Posts: 26,930
    edited May 2013
    SCompRacer wrote: »
    Also on commercial gear
  • Drenis
    Drenis Posts: 2,871
    edited May 2013
    BlueFox wrote: »
    Dynamat. It's design is to stop vibrations and dampen ringing. It also cuts down on external (road) noise when applied in vehicles.
  • polkfarmboy
    edited May 2013
    What are you using for usb cords to link them badboys up
