Removal of Armacell
Reagan
Reagan Posts: 116
edited March 2013 in DIY, Mods & Tweaks
I have heard good things about Armaflex. However, has anyone else tried to remove the tape? I installed some Armaflex TAP18230 insulation tape for my tweeters on my 1.2TL's. When installing Larry rings I had to remove the Armacell to drill the holes. It was very difficult to tear off without destroying the MDF below. This makes me very hesitant to continue installing Armaflex. Any input?
Speakers: Polk 1.2TL w/VR3 mods and Dreadnaught interconnects
Amplification: ARC Reference 110 w/KT150s; Cary Audio SLP-05 w/Ultimate Upgrade
Vinyl: VPI HW19 MK III (Heavily Modded); Origin Live Silver Tonearm; Hana ML Cart; Pete Riggle VTAF; VPI TNT Platter; SAMA; Iphono3
Digital: Aurender N100H; Benchmark DAC1
Post edited by Reagan on
  • GospelTruth
    GospelTruth Posts: 403
    edited March 2013
    Rather than putting the tape directly on the speaker cabinet, you should be putting the tape on the back side of the drivers, around the outer rim. This way you aren't needing to remove anything from the MDF cabinet. That should allow you to have the benefit you are looking for without the issues you are encountering.
    Speakers
    Polk 5jr+
    Polk SDA 2B
    Polk SDS 3.1TL
    Equipment
    Yamaha RX-V3800 Receiver
    Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable
  • nspindel
    nspindel Posts: 5,343
    edited March 2013
    +1. Adhesive side goes to the driver/tweeter/etc., not the cabinet.
  • Reagan
    Reagan Posts: 116
    edited March 2013
    Thanks for the response.
    nooshinjohn Posts: 25,931
    edited March 2013
    Agreed with the rest. The adhesive side goes to the driver. It should be easily removed with just a bit of goo be gone and an exact knife if you did it the other way around. Just take your time with it.
  • westmassguy
    westmassguy Posts: 6,850
    edited March 2013
    Reagan wrote: »
    As other have said, apply the gasket material to the driver from now on. I've been guilty of doing the same thing. Judicious use of a hair dryer helped soften the adhesive, and made removal from the particle board easier. Unfortunately, some of the adhesive will still remain on the particle board. Acetone or nail polish remover will get most of it off, just be careful not to get any on the black textured vinyl Polk used on the front baffle.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Reagan
    Reagan Posts: 116
    edited March 2013
    I was able to get almost all of the stuff off with several pencil erasers and razor (scraped with razor perpendicular to surface). Thanks for not lighting me up too badly for this dumb mistake.
  • westmassguy
    edited March 2013
    Reagan wrote: »
    We all do that on occasion
