playing multiple sets of speakers
leftwinger57
I have 3 sets of 8ohm speakers in the same room. I will not entertain playing all three but 2 I think is an option.
I have a Niles speaker selector w/ a protection button on the end I believe it's for this purpose. Now I also think my Adcom wouldn't break a sweat w/ this either.I just want to know if this is advised ,stupid ,or not healthy for the gear involved. Why you ask ,only because I can no other reason and of course it's not needed between any of the sets I have.
Perfectly fine with the protection button pushed in.
Even without protection, you should be okay with 2 pairs, even 3 pairs should be okay at normal volume.
I use Niles 6 and only run 1 pair most of the times but I use protection when running more than one pairs since my speakers are 4 or 6 ohms and also driven by a HT receiver.
Thanks ,short to the point and quite informative.....2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
We have piles and piles of Adcom amps and Niles speaker selectors in houses all over Long Island from the 90s still kicking away. Go for it!B&W CM9Classé Sigma
