Speaker wires....should I purchase higher gauge??
Mak06053
I have an older entry level Onkyo HTIB and just upgraded to polk tsi300s and a CS20. Should I buy different speaker wire and use instead of what can with the Onkyo speakers??? Thank you.
Post edited by Mak06053 on
Yes !!! Get new wire.
If you stick around here long enough you'll encounter one of our perennial flaming cable debates! But I'm pretty sure that even the skeptics would "agree" that a higher quality lower gauge copper wire will yield acoustic benefits! So yes, get rid of that cheap Onkyo cable and get some LOWER gauge cable. (At the very least, 14 gauge).
You mean "lower" gauge as 14 is thicker than 16 which is thicker than 18, etc.!
Thanks guys I appreciate the help......
since you did not state the model of the Onkyo or say what type of speaker connectors it has. May have a defining approach on what guage of wire you will be able to use. If your Onkyo has banana plugs you are in great shape and size wil not be an issues, but if it has spring loaded or close cap type then you may be limited to 14-16 or higher.Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Fluance bipolar Rear Surrounds FluanceXF8 Bookshelf Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp x2, Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Polk Audio R700 Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX301 Eversolo DMP-A6 Polkaudio R600 Towers Polkaudio Center R350 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Fluance Signature Bookshelf fronts, Rears Fluance Signature Bipolar Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX
yes.Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
If you want to get new wire for the Onkyo then your best bet is to buy the heavy gauge wire from mono price. I used the monprice wire with my onkyo and it was fantastic, I even did an A to B comparison with cheap panasonic htib type wire and the difference was astounding. The monoprice wire really opened the speaker wide up and it sounded soooooo much better than the other htib wire that was thinner than noodles
Rofl...I agree 100%. Upgrade your wire..If you stick around here long enough you'll encounter one of our perennial flaming cable debates! But I'm pretty sure that even the skeptics would "agree" that a higher quality lower gauge copper wire will yield acoustic benefits! So yes, get rid of that cheap Onkyo cable and get some LOWER gauge cable. (At the very least, 14 gauge).
cnhATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables -
Definitely have a look at Blue Jeans, as Face suggests above.
Good cables at reasonable prices, and they will make them to fit for you.Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
www.knukonceptz.com I like the !0 gauge good stuff 492 copper strandsBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
- Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere
-Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers -
cnh
+1. Also, Faces recommendation is a good place to start._____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
My current receiver has the spring loaded, but will be upgrading receiver hopefully in the next couple of months
After using the same wire for speaker cables for a long time don't the copper wires get all clogged up with neutrinos that prevent the flow of electrons from the amp to the speakers?
I like to use 4/0 welding cable for my setup!"Everything I ever did in my life worthwhile I caught hell for"
I just steal power lines. My room smells like bird **** and ozone!Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
If you wanted a serious answer, check this out:
http://www.webervst.com/gauge.htm
Put in your amp's rated power, the ohm rating of your speaker, the length of the cable run, and hit calculate. That will give you the minimum ideal cable gauge that you should use. Keep in mind that using a better gauge than that will increase damping factor (the amp's ability to bring the driver to a halt) at the speaker itself. You can see this effect here:
http://www.bcae1.com/dampfact.htmEquipment list:
Emotiva XPA-3 amp
Good suggestion. -
Yes. I would get higher gauge cables
Hi guys I'm new to the home theatre game and this speaker gauge question gots me wondering about my own set up. I have a denon avr with polk speakers hooked up by 16 gauge rocket fish speaker wire, am I wrong by using this size and type of wire? I thought my set up sounded good but now u guys got me wondering if it can sound better with different wire. Any help is very much appreciated.
See the links in my post above. Whether you'll hear a difference, who knows? But you want to at least use the minimum gauge wire required to get ideal signal to your speakers.Equipment list:
Emotiva XPA-3 amp
knukonceptz has a flee bay store they have 8 gauge twisted tinned oxygen free copper 805 strands per conductor for $1.65 per foot plus $5 dollars shipping:cheesygrin:Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Just ordered some speaker cable from blue jeans for my fronts and center channel can't wait to hook them up. I'm curious to see if it makes a difference in sound :cheesygrin:
