Speaker wires....should I purchase higher gauge??
Mak06053
Mak06053 Posts: 44
I have an older entry level Onkyo HTIB and just upgraded to polk tsi300s and a CS20. Should I buy different speaker wire and use instead of what can with the Onkyo speakers??? Thank you.
Post edited by Mak06053 on
  • chumlie
    chumlie Posts: 8,658
    edited March 2013
    Yes !!! Get new wire.
    edited March 2013
    If you stick around here long enough you'll encounter one of our perennial flaming cable debates! But I'm pretty sure that even the skeptics would "agree" that a higher quality lower gauge copper wire will yield acoustic benefits! So yes, get rid of that cheap Onkyo cable and get some LOWER gauge cable. (At the very least, 14 gauge).
    You mean "lower" gauge as 14 is thicker than 16 which is thicker than 18, etc.!
    cnh
  • Face
    Face Posts: 14,340
    edited March 2013
  • Mak06053
    Mak06053 Posts: 44
    edited March 2013
    Thanks guys I appreciate the help......
  • recoveryone
    recoveryone Posts: 929
    edited March 2013
    since you did not state the model of the Onkyo or say what type of speaker connectors it has. May have a defining approach on what guage of wire you will be able to use. If your Onkyo has banana plugs you are in great shape and size wil not be an issues, but if it has spring loaded or close cap type then you may be limited to 14-16 or higher.
  • michael1947
    michael1947 Posts: 775
    edited March 2013
    yes.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited March 2013
    If you want to get new wire for the Onkyo then your best bet is to buy the heavy gauge wire from mono price. I used the monprice wire with my onkyo and it was fantastic, I even did an A to B comparison with cheap panasonic htib type wire and the difference was astounding. The monoprice wire really opened the speaker wide up and it sounded soooooo much better than the other htib wire that was thinner than noodles
  • Jhayman
    Jhayman Posts: 1,548
    edited March 2013
    Rofl...I agree 100%. Upgrade your wire..
    cnh wrote: »
    cnh
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited March 2013
    Definitely have a look at Blue Jeans, as Face suggests above.
    Good cables at reasonable prices, and they will make them to fit for you.
  • K-daugh
    K-daugh Posts: 467
    edited March 2013
    www.knukonceptz.com I like the !0 gauge good stuff 492 copper strands
    Budget 5.1 H.T. Set Up
    HK avr 247 - Adcom GFA-7605:mrgreen::mrgreen: - Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
    Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
    Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere:mrgreen: -Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
    Custom Jumpers
  • Thorton
    Thorton Posts: 1,324
    edited March 2013
    cnh wrote: »
    cnh
    +1. Also, Faces recommendation is a good place to start.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • Mak06053
    Mak06053 Posts: 44
    edited March 2013
    My current receiver has the spring loaded, but will be upgrading receiver hopefully in the next couple of months
  • Sprags
    Sprags Posts: 120
    edited March 2013
    After using the same wire for speaker cables for a long time don't the copper wires get all clogged up with neutrinos that prevent the flow of electrons from the amp to the speakers?
  • bobsauto49
    bobsauto49 Posts: 973
    edited March 2013
    I like to use 4/0 welding cable for my setup!
    "Everything I ever did in my life worthwhile I caught hell for"
  • kuntasensei
    kuntasensei Posts: 3,263
    edited March 2013
    I just steal power lines. My room smells like bird **** and ozone!
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • kuntasensei
    edited March 2013
    If you wanted a serious answer, check this out:
    http://www.webervst.com/gauge.htm
    Put in your amp's rated power, the ohm rating of your speaker, the length of the cable run, and hit calculate. That will give you the minimum ideal cable gauge that you should use. Keep in mind that using a better gauge than that will increase damping factor (the amp's ability to bring the driver to a halt) at the speaker itself. You can see this effect here:
    http://www.bcae1.com/dampfact.htm
    Equipment list:
    Emotiva XPA-3 amp
  • Lost240
    Lost240 Posts: 176
    edited March 2013
    Yes. I would get higher gauge cables
  • mrmoeone
    mrmoeone Posts: 12
    edited March 2013
    Hi guys I'm new to the home theatre game and this speaker gauge question gots me wondering about my own set up. I have a denon avr with polk speakers hooked up by 16 gauge rocket fish speaker wire, am I wrong by using this size and type of wire? I thought my set up sounded good but now u guys got me wondering if it can sound better with different wire. Any help is very much appreciated.
  • kuntasensei
    edited March 2013
    See the links in my post above. Whether you'll hear a difference, who knows? But you want to at least use the minimum gauge wire required to get ideal signal to your speakers.
    Equipment list:
    Emotiva XPA-3 amp
  • K-daugh
    K-daugh Posts: 467
    edited March 2013
    knukonceptz has a flee bay store they have 8 gauge twisted tinned oxygen free copper 805 strands per conductor for $1.65 per foot plus $5 dollars shipping:cheesygrin:
    Custom Jumpers
  • mrmoeone
    mrmoeone Posts: 12
    edited March 2013
    Just ordered some speaker cable from blue jeans for my fronts and center channel can't wait to hook them up. I'm curious to see if it makes a difference in sound :cheesygrin:
