shut down pop adcom
htrdln
So I purchased the adcomgfa5805 and it sounds great. Its hooked to the 12v trigger on my Denon 4310ci the problem I'm having is that when I turn of the denon I get a pop sound out of the tweeters.
Post edited by htrdln on
IMO the pop is from the Denon and Adcom shutting off at the same time. The Adcom amp has no output relay, so any signal at the input will continue to be amplified after power-down until the power supply caps discharge. Best practice is to always power down the amp first, then the preamp, so that turn-off noises in the preamp are not amplified by the amp. That is not happening with your Denon trigger. Unless the pop is very loud, I would not worry about it.Main System: Denon DP-59L | Audio-Technica AT33EV | Marantz SA-11S2 | Classe DR-10 | Classe CA-300 | Classe RC-1 | PSB Stratus Gold i's | DIY Balanced AC Power Conditioner | Acoustic Zen and NeoTech cables | Oyaide and Furutech power connectors | Dedicated 20A isolated ground line.
Party System: Laptop #2 | Audioquest Dragonfly USB DAC | Technics SU-A6 | Acurus A-250 | Radio Shack 15-band EQ | Pioneer SR-9 reverb | Cerwin Vega DX9's | Dayton 100° x 60° horns with titanium HF/MF compression drivers. -
My 555II has the same pop sound with my Onkyo 809 but not H/K 7550D.MAIN:
Front- LsiM 707 (MIT Terminator 2 Bi-Wire),
Center- lsiM 706,
Surrounds- lsi F/X,
Power sub PSW1000,
Receiver- Harman Kardon Avr 3700,
Amp - Emo XPR-5.
Secondary (2.1):
LsiM 703,
HK Avr 3700,
Yaqin MS-30L,
Polk DSW-PRO 400. -
My Adcom 555 dead silent on start up which is immediate, but on shut down I do get that deflating ballon sound .You just imagine those capacitors spooling down.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
It's normal with a lot of Adcom equipment. I had two 535 amps, both did it.If you can't hear a difference, don't waste your money.
Thanks guys just got the lsi25 for Christmas so am still habit paranoid.. lol
I wonder if you could get the proper delay by using something like the Belkin PF60 that I'm using. It lets you feed 12v trigger to the unit, then assign a delay to the 12v trigger output and any switched outlet banks you assign. Just a thought.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
i disconected the 12volt trigger and the pop is gone.
That's a good suggestion. Its triggering options and programmable delay is perfect for the OP's Adcom. I have a PF-60 in my HT system, and at one time used it to turn on/turn off my Phase Linear Series 2 amp, which has no power switch.kuntasensei wrote: »I wonder if you could get the proper delay by using something like the Belkin PF60 that I'm using. It lets you feed 12v trigger to the unit, then assign a delay to the 12v trigger output and any switched outlet banks you assign. Just a thought.Main System: Denon DP-59L | Audio-Technica AT33EV | Marantz SA-11S2 | Classe DR-10 | Classe CA-300 | Classe RC-1 | PSB Stratus Gold i's | DIY Balanced AC Power Conditioner | Acoustic Zen and NeoTech cables | Oyaide and Furutech power connectors | Dedicated 20A isolated ground line.
