shut down pop adcom
htrdln
htrdln Posts: 116
edited March 2013 in Electronics
So I purchased the adcomgfa5805 and it sounds great. Its hooked to the 12v trigger on my Denon 4310ci the problem I'm having is that when I turn of the denon I get a pop sound out of the tweeters.
Post edited by htrdln on
  • ZLTFUL
    ZLTFUL Posts: 5,650
    edited March 2013
    My 555s give a mild thump when they shut down but nothing that I find concerning. Don't know much about the 5805 though.
  • Glen B
    Glen B Posts: 269
    edited March 2013
    IMO the pop is from the Denon and Adcom shutting off at the same time. The Adcom amp has no output relay, so any signal at the input will continue to be amplified after power-down until the power supply caps discharge. Best practice is to always power down the amp first, then the preamp, so that turn-off noises in the preamp are not amplified by the amp. That is not happening with your Denon trigger. Unless the pop is very loud, I would not worry about it.
  • xftman
    xftman Posts: 153
    edited March 2013
    My 555II has the same pop sound with my Onkyo 809 but not H/K 7550D.
    MAIN:
    Front- LsiM 707 (MIT Terminator 2 Bi-Wire),
    Center- lsiM 706,
    Surrounds- lsi F/X,
    Power sub PSW1000,
    Receiver- Harman Kardon Avr 3700,
    Amp - Emo XPR-5.
    Secondary (2.1):
    LsiM 703,
    HK Avr 3700,
    Yaqin MS-30L,
    Polk DSW-PRO 400.
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited March 2013
    My Adcom 555 dead silent on start up which is immediate, but on shut down I do get that deflating ballon sound .You just imagine those capacitors spooling down.
  • decal
    decal Posts: 3,205
    edited March 2013
    It's normal with a lot of Adcom equipment. I had two 535 amps, both did it.
  • htrdln
    htrdln Posts: 116
    edited March 2013
    Thanks guys just got the lsi25 for Christmas so am still habit paranoid.. lol
  • kuntasensei
    kuntasensei Posts: 3,263
    edited March 2013
    I wonder if you could get the proper delay by using something like the Belkin PF60 that I'm using. It lets you feed 12v trigger to the unit, then assign a delay to the 12v trigger output and any switched outlet banks you assign. Just a thought.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • htrdln
    htrdln Posts: 116
    edited March 2013
    i disconected the 12volt trigger and the pop is gone.
  • Glen B
    Glen B Posts: 269
    edited March 2013
    That's a good suggestion. Its triggering options and programmable delay is perfect for the OP's Adcom. I have a PF-60 in my HT system, and at one time used it to turn on/turn off my Phase Linear Series 2 amp, which has no power switch.
