14/4 carol cable for surrounds
K-daugh
looking to run some 14/4 carol cable for my rear speakers in my new place .. Anyone have experience with carol cable I've used it for power cords ...had some laying around..
Budget 5.1 H.T. Set Up
HK avr 247 - Adcom GFA-7605Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere
Custom Jumpers
Post edited by K-daugh on
I want to bi wire the 30'sBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
- Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
-Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers -
Why not try it and hear for yourself?If you can't hear a difference, don't waste your money.
well i was thinking id throw the question out there first ...most likely ill be using 12/4 monoprice because i dont have enough of the carol but if i got some good feedback i may buy some of the carol cable .....about 3/4 of the run will be in the basement the total run is about 25'Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
if i really wanted to get lazy i could use that ultra flat thin monster ....i think its too thin though ....idk ...i have a friend thats a proffessional av guy does a lot of commercial stuff some residential he doesn't use anything bigger than 16 gauge...i'd like to agree with him it would be cheaperBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Carol Cable is an main line wire & cable manufacture for many decades.
I've used the Carol Cable 14/2 on my fronts and didn't have any problems. In fact, it was probably the best stuff I've worked with in terms of ease of use. The stuff is flexible and easy to terminate. And here's the fun part. I paid maybe $10 for 30 feet from Home Depot since it was on their leftover wire shelf and I bought it to see if there would be any difference between it and Monster Z Series Speaker Cables I was using at the time. No difference from what I could tell. The Monster cables were on Craigslist the next day.Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD -
As speedskater has already said Carol Cable CO. has been around for a long time . If you don't buy into the snake oil $200 ' wire then
you'll be fine. I used construction grade 16/4 to p/u my rears and have not had any issues w/ either the length of run or any
degrading of sound quality.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
leftwinger57 wrote: ». If you don't buy into the snake oil $200 ' wire then
you'll be fine.
Couldn't leave well enough alone....ya had to throw that line in there ?HT SYSTEM-
lsi 9's -
At the very least, I'd consider spending just a little bit more and opt for Blue Jeans Cable, Beldon 5000U.
yep that Beldon 5000u is darn nice cable for the price... -
ended up using this http://www.knukonceptz.com/productMaster.cfm?category=Kord%20Speaker%20WireBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Gee, that wire shop is about a 1/2 hour drive from my house.
I think you will be happy with it, for the money. I used Knukonceptz 14/2 for my fronts and center, and 16/2 for my surrounds and I think it sounds great. More definition than the cheap lamp cord I was using. Their 14/2 stranded wire is made up of 189 individual strands and both gauges are very flexible and easy to terminate. -
I used the kord cable 10 gauge 492 strands per conductor with nakimichi banana plugs ...Im saving for the knukonceptz banana plugs those are pretty nice!!Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Stick with the nakimichi plugs for now. I like the way the Knu plugs are built but I have read on here that they are not solid copper.
good to know ..thanks hey you happen to know anyone who works on subwoofers (the amp section) I know its off topic but I thought i would throw it out there ...I didnt really get a response to the thread I started in the Subwoofer bass management sectionBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Sorry, no but you would want to find someone local because shipping would be a killer on a sub -
last 3 aholes reportedIf you can't hear a difference, don't waste your money.
If its "power" cable, its not speaker cable and its not usually 99+% pure. You can do a bit better without going nuts. Look up Windy City 14/4. If inclined, you can double it up and have 10 gauge.The MAINE System
Marantz AV7005
2 Carver M200t's biamped, Adcom GFA 7000
Pioneer DV-46A, Lightspeed
Polk LSi 15's, PMC DB1+C, Polk LSi7, Sunfire True Sub II
Samsung HP-T1254 42in Plasma
Kubala Sosna Center wiring, DAO Kubala Sosna , Apature & Monster HDMI's
The CT System
Marantz AV7005
MacIntosh MC352, Marantz MM7705w/Sig. upgrade
Polk LSi15's, Golden Ear Technologies Sat 50's & 50C
Kubala Sosna Speaker wire, Audioquest interconnects and assorted other goodies
