Car Gurus: How do I change a serpentine belt on a front wheel drive?
Serendipity
Serendipity Posts: 6,975
edited March 2013 in The Clubhouse
So over the past week my serpentine belt has been squealing upon start-up, and the sound would eventually go away after a few seconds of driving. I took the car in for NY State inspection and was told I need a new serpentine belt, and this isn't covered under warranty. So I bought the belt from the dealer, along with some other stuff like brake pads and fluids. The problem is, I can't seem to figure out how to get the belt off. There's an automatic belt tensioner, which I'm assuming I need to loosen - just need to get the belt removed and put the new one on.
Any ideas? I have a '12 Nissan Versa with the HR16DE engine and manual transmission. I've already completed the tune-up (1st major service) and replaced the brake pads, all I have left is to get this belt on.
Thanks in advance!
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
  • chumlie
    chumlie Posts: 8,658
    edited March 2013
    Major pain to do yourself. Take it to a pro. Good luck !!!
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited March 2013
    The automatic tension pulley is usually on a spring loaded arm. Use a breaker bar and socket to relieve tension on the belt. It's pretty simple, although probably a tight squeeze with such a small car. May help to have someone help hold the breaker while you route the belt.
    I'm surprised a 2012 needs a new belt already. I usually get at least 10 years out of them.
  • Serendipity
    edited March 2013
    Thanks William. I tried to use a socket but there's no room to get anything in there. Unless there's some sort of low-profile socket wrench that bends, I can't see myself getting anything in between there.
  • monepolk
    monepolk Posts: 1,154
    edited March 2013
    I bought a tool, a flat style bar, for that from Harbor Freight, it was a set of two different lengths and I think it was $15. Not sure what you mean by it needs to bend? Some you have to access from underneath the vehicle.
  • Serendipity
    edited March 2013
    It needs to bend because of a metal bar that blocks the socket wrench from going in straight. It has to go in at an angle on this car for some reason. Very different from an American V8 where the belt is right by the radiator and easily accessible.
    I'm going to take a trip to the auto parts store and see what I can find.
    Also, I'm really glad I didn't buy this car used (as some here suggested) - I'd rather have less headaches and a full warranty. The cost savings would probably equal the increased costs down the road.
  • monepolk
    edited March 2013
    The auto parts store should have what you need.
    gudnoyez Posts: 8,174
    edited March 2013
    A 2012 model already needing a tune up, brake pads, and a new serpentine belt, have you even had it 12 months? How many miles on it?
  • Serendipity
    edited March 2013
    I cross the tip of Manhattan every day, 5 days a week, in rush hour traffic. I already have 21,000 miles and haven't even owned the car for a year. Did the brakes at 20,500 miles. Mechanic said I'll also need a new clutch soon as it's engaging near the top. NYC traffic really, really sucks.
  • sucks2beme
    sucks2beme Posts: 5,691
    edited March 2013
    Ding! Most parts stores sell a kit. Or cut off an old wrench and weld on a long piece of pipe.
    Or just take it to a shop. There may be more going on than just a belt.
  • gdb
    gdb Posts: 6,012
    edited March 2013
    When done by someone who knows what they're doing.........it takes all of a minute or three to change one of those belts. Find such a person ! :lol:
    nooshinjohn Posts: 26,000
    edited March 2013
    Take the car to Nissan and have them do it under warranty. Ther is a strong chance the tensioner damaged the belt. At any rate, a belt failing with those kind of miles is a warranty issue.
    edited March 2013
    Have to agree here. A year old car needing a new belt, something else is amis. Same with the breaks, 20 thousand miles ? Hope your not riding the break pedal or the clutch pedal for that matter. Haven't changed the serpentine belt yet on either of my cars and they are 17 years old and 15 years old, one over 200,000 miles and the other 180,000. I usually get 40,000 miles out of a set of brakes.
  • decal
    decal Posts: 3,205
    edited March 2013
    Do they have a "Lemon Law" in your state?
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited March 2013
    Sounds like 21k miles City is like 135k miles on a highway!
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    billbillw Posts: 7,797
    edited March 2013
    Those belts are typically rated for at least 60k miles, many are 100k miles. Take it to the dealer! Make an issue out of it. Be firm! No car with 21k miles should need a new serpentine belt unless there is a defect, which should be covered under warranty.
  • Serendipity
    edited March 2013
    I actually did take it to the dealer, and they said it's not covered under warranty. I did admit the mileage was all city, which probably didn't help my case. For reference, I just changed the brakes on our other car, which sees more highway use, and got 50,000 miles out of the original pads (front) and the rears still looked brand new! Same driving style, just different driving conditions.
  • Serendipity
    edited March 2013
    tonyb wrote: »
    I agree, see my post above. So what's the best way to "crawl" in stop-and-go traffic without wearing the clutch? If the road is facing uphill, and traffic speeds are less than 1MPH, I've always had to hold the clutch in halfway to creep up slowly (otherwise, you'll roll backwards). That probably contributed to the wear, if there's a better way I'm all ears.
  • brgman
    brgman Posts: 2,859
    edited March 2013
    Buy a car with an auto trans.
    That's the worst situation you could be driving in with a clutch on so many levels.
    You'll burn thru that car in no time.
    I’M OFFENDED!!!!
  • Serendipity
    edited March 2013
    brgman wrote: »
    Yikes! I've been driving this car thru the city for the past 21k miles day in, day out and my daily commute has some pretty big hills!
    disneyjoe7 wrote: »
    I agree. Mileage counters don't account for run time and traffic. 1 hour of highway (60 miles) might only be a few miles city!
  • brgman
    brgman Posts: 2,859
    edited March 2013
    I love cars and trucks with clutches but doing that every day,no way.Screw dat!
    I’M OFFENDED!!!!
  • sda2mike
    sda2mike Posts: 3,131
    edited March 2013
    Disconnect the lower motor mount. place a wood block on a jack and slowly raise the sumbitch up by the oil pan. that should give you access on the business end of the engine. i doubt thats the serp belt sqeeling. theyre usually toothed and wldnt make that sound. idler pulley or water pump. car is way too new. good luck
  • michael1947
    michael1947 Posts: 775
    edited March 2013
    This can get kind of complicated with a chance of injury to your finger tips. Belts are simple but you must have experience and equipment. Look for a second opinion and a light weight garage something like Pep Boys. If you don't have a second car it's quite possible you will be renting a ride. A 2012 car absolutely should not have this problem.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited March 2013
    Automobile manufacturers, like most equipment manufacturers, have warranty coverage, which is always advertised, and they also have a less advertised kind of coverage usually called "policy." Policy coverage differs from warranty coverage because whether a complaint qualifies for it or not is a matter of judgment by somebody outside the dealership or retail shop. To get policy coverage you have to argue that even if the warranty does not cover your particular problem, as a matter of policy, the manufacturer would not want their products to fail in the way you have experienced, and they should not fail in that way. The dealer should help you connect with the right person to get this coverage -- e.g., "VP for Nissan Quality in North American Operations" or some such title or person.
    My bet is that if you persist, you will get relief. My persistence in this vein has been successful with John Deere for a snowblower on my 4400 tractor, Lexus for a seat that did not function the way the sales person explained that it would to my wife and me, with Baldwin Brass with respect to the finish on lock sets in our house, with Jado with respect to the core assembly in a shower mixer, with Kohler for a generator set that failed with only 244 hours on it (partially successful), and with Grohe with respect to a small rubber cover and a plastic connector on a kitchen faucet assembly with a removable handspray.
    These manufacturers set aside funds on their balance sheets for "Warranty and Policy." They are there to cover these kinds of problems with there products that shouldn't happen and that are not from abuse or misuse by their customers. Just don't let them make their problem seem like your problem.
    A little advice from an old curmudgeon in New England! :smile:
    Good luck!
  • obieone
    obieone Posts: 5,077
    edited March 2013
    The standard for new cars is "36 months/ 36,000 mile BUMPER TO BUMPER WARRANTY"!!!
    I'm pretty sure that belt is included.
    You live in the KING of the Nanny states, all you have to do is write an email to the state AG, and cc the GM of that dealership, and the local tv stations consumer products reporter. Hell, they'll prolly extend your warranty for free.
    edited March 2013
    brgman wrote: »
    Bingo.....I have to ask the OP why he bought that car knowing the driving conditions ahead of time.
    Maybe best to trade that car in while newer for one with an automatic. Just what you'll save in clutches and brakes should be worth it.
    SCompRacer Posts: 9,121
    edited March 2013
    I used the park brake to hold from rolling on inclines when I drove stick.
    edited March 2013
    Never ride the clutch like that. Simple way is don't drive at 1mph. Wait till there is a gap, accelerate, full clutch out. Clutch in when you have to stop. With a clutch car, you just have to be that person who is stop and go vs slowly creeping along.
  • Serendipity
    edited March 2013
    tonyb wrote: »
    It's my first stick car, so I didn't really know what to expect other than "it's fun to drive" and "it's more engaging than an automatic," which was what I was told by people such as Bigaudiofanatic. I quickly found out it was not much fun after driving in NYC traffic for a day. By that time I had already put 100 miles on the car (mostly learning miles) and figured I would get used to it. I'm not sure if I would ever buy a manual again unless I lived in a rural area. It's just too much work to deal with slow moving traffic.
  • heartystatue
    heartystatue Posts: 329
    edited March 2013
    Take the passenger front tire off. Undo the fender well lining.Look above the crank pulley to see the tensioner. Use a 114mm wrench rotate towards the rear of the car. Should come off. These are instructions off Nissan Versa forum.
    Good luck!!!!
    HT: LSI15, LSIC, LSIFX, Emo XPA-3:biggrin: Onkyo TXNR809, Sony BDP-S500, PannyDMP-BDT320, MIT S1 SC. Mit 73842dlp
    2ch: SDA-SRS 2.3 Fully modded. BAT VK500 w/batpak, BAT VK5I, Essence HDACC.
  • Moose68Bash
    edited March 2013
    Serendipity,
    Don't let these guys make you feel guilty for buying the car you wanted to buy. There is principle in Total Quality Management/Total Quality Control ("TQM" or "TQC") to which I am sure Nissan subscribes in one form or another.
    This principle addresses a concept called "Design for Use." It means that the engineering of the vehicle should be designed in such a way as to meet expected driving conditions. It is the manufacturer's representative's responsibility to ask you, the customer, how you plan to use the vehicle he/she is trying to sell you. If he/she didn't ask you this fundamental question because selling the car was more important than meeting your needs and expectations, then it's his/her "bad," not yours. If the literature that advertised the vehicle or came with it did not specify that it should not be used for extensive driving in high-traffic conditions, Nissan's "bad," not yours. Really, do you believe driving in Tokyo does not involve stop and go traffic? Been there, done that! It does! Beats New York IMHO.
    The manufacturer should remedy their mistake, not send you off to pay for the repair.
    As one of Japan's leading auto manufacturers, I am sure Nissan follows TQM/TQC practices, and I'm sure that if you persist you will "win." My argument with Lexus about the operation of the passenger-side seat in the LS400 I purchased in 1991 revolved around the salesperson's statement that the passenger seat in the front "operated just like the driver's seat." This statement was false. When we took delivery of the car, my wife could not adjust the seat up and down. Consequently, she couldn't ride as a passenger in the foothills of the SF Bay Area without becoming nauseous. After my persistence, Lexus actually offered to take the car back and fully refund our money -- purchase price, taxes, licensing fees, etc.
    I loved the car, I proposed another solution which Lexus implemented without cost to us. Lexus's action is what Japanese TQM/TQA is all about. Go for it.
