what bluetooth headphones to buy?
folkknow
folkknow Posts: 2
edited March 2013 in Headphones
I use a nexus 10 often. I would like to use headphones with no cord. What would be an inexpensive choice? I also walk to work. Is there a good cordless option for physical activity?
Post edited by folkknow on
  • jame22
    jame22 Posts: 1
    edited March 2013
  • Gadabout
    Gadabout Posts: 1,072
    edited March 2013
    The only bluetooth set I have is the Motorola SD-10HD. I mainly use them when I'm doing yard work.
    The sound is OK. I mainly got them because I didn't want to deal with a cord while working. I usually connect them to the phone as they have call answering switches and a mic. They are more for convenience than sound quality. New you can find them for around $45. I got mine from Woot, refurbished for $25. Bought a couple for friends at Christmas.
    I recommend them for convenience. I'm sure others will have better sound quality.
    The best sounding bluetooth Headphone I have heard is the Sennheiser MM 450. They have a new model out the 550's but the 450's have dropped in price to a little over $200. These models both offer noise canceling. I know they are out of your stated price range, but they do sound pretty good.
    Scott
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • Lost240
    Lost240 Posts: 176
    edited March 2013
    Won't bluetooth headphones drain your battery quickly?
  • zingo
    zingo Posts: 11,258
    edited March 2013
    Whatever you get, make sure it works on the A2DP blutooth profile which is higher quality and designed for music and other entertainment listening.
  • Gadabout
    edited March 2013
    If you haven't bought anything yet, WOOT has the Motorola S10-HD refurbs on sale again. $24.99
    If you Interested......
    http://tech.woot.com/#
    Scott
