14/4 carol cable for surrounds
K-daugh
K-daugh Posts: 467
looking to run some 14/4 carol cable for my rear speakers in my new place .. Anyone have experience with carol cable I've used it for power cords ...had some laying around..
Budget 5.1 H.T. Set Up
HK avr 247 - Adcom GFA-7605:mrgreen::mrgreen: - Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere:mrgreen: -Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers
Post edited by K-daugh on
  • K-daugh
    K-daugh Posts: 467
    edited February 2013
    I want to bi wire the 30's
    Custom Jumpers
  • decal
    decal Posts: 3,205
    Why not try it and hear for yourself?
  • K-daugh
    K-daugh Posts: 467
    well i was thinking id throw the question out there first ...most likely ill be using 12/4 monoprice because i dont have enough of the carol but if i got some good feedback i may buy some of the carol cable .....about 3/4 of the run will be in the basement the total run is about 25'
    Custom Jumpers
  • K-daugh
    K-daugh Posts: 467
    if i really wanted to get lazy i could use that ultra flat thin monster ....i think its too thin though ....idk ...i have a friend thats a proffessional av guy does a lot of commercial stuff some residential he doesn't use anything bigger than 16 gauge...i'd like to agree with him it would be cheaper
    Custom Jumpers
  • Speedskater
    Speedskater Posts: 495
    Carol Cable is an main line wire & cable manufacture for many decades.
  • HTguru1982
    HTguru1982 Posts: 1,066
    I've used the Carol Cable 14/2 on my fronts and didn't have any problems. In fact, it was probably the best stuff I've worked with in terms of ease of use. The stuff is flexible and easy to terminate. And here's the fun part. I paid maybe $10 for 30 feet from Home Depot since it was on their leftover wire shelf and I bought it to see if there would be any difference between it and Monster Z Series Speaker Cables I was using at the time. No difference from what I could tell. The Monster cables were on Craigslist the next day.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited March 2013
    As speedskater has already said Carol Cable CO. has been around for a long time . If you don't buy into the snake oil $200 ' wire then
    you'll be fine. I used construction grade 16/4 to p/u my rears and have not had any issues w/ either the length of run or any
    degrading of sound quality.
    edited March 2013
    you'll be fine.
    Couldn't leave well enough alone....ya had to throw that line in there ?
    pitdogg2 Posts: 27,196
    edited March 2013
    Keiko wrote: »
    At the very least, I'd consider spending just a little bit more and opt for Blue Jeans Cable, Beldon 5000U.
    yep that Beldon 5000u is darn nice cable for the price...
  • K-daugh
    K-daugh Posts: 467
    edited March 2013
    Custom Jumpers
  • Speedskater
    edited March 2013
    Gee, that wire shop is about a 1/2 hour drive from my house.
  • Jimbo18
    Jimbo18 Posts: 2,351
    edited March 2013
    K-daugh wrote: »
    I think you will be happy with it, for the money. I used Knukonceptz 14/2 for my fronts and center, and 16/2 for my surrounds and I think it sounds great. More definition than the cheap lamp cord I was using. Their 14/2 stranded wire is made up of 189 individual strands and both gauges are very flexible and easy to terminate.
  • K-daugh
    K-daugh Posts: 467
    edited March 2013
    Jimbo18 wrote: »
    I used the kord cable 10 gauge 492 strands per conductor with nakimichi banana plugs ...Im saving for the knukonceptz banana plugs those are pretty nice!!
    Custom Jumpers
  • Jimbo18
    edited March 2013
    Stick with the nakimichi plugs for now. I like the way the Knu plugs are built but I have read on here that they are not solid copper.
  • K-daugh
    K-daugh Posts: 467
    edited March 2013
    Jimbo18 wrote: »
    good to know ..thanks hey you happen to know anyone who works on subwoofers (the amp section) I know its off topic but I thought i would throw it out there ...I didnt really get a response to the thread I started in the Subwoofer bass management section
    Custom Jumpers
  • Jimbo18
    edited March 2013
    K-daugh wrote: »
    Sorry, no but you would want to find someone local because shipping would be a killer on a sub
  • rojeskhd45
    rojeskhd45 Posts: 1
    edited March 2013
    You could start to test it as well as listen to for you?
    Local Town Dealz delivers Bel Air's best restaurant deals, spa deals, happy hour deals, nightlife deals, dining deals, Bel Air, coupons, deals
  • decal
    decal Posts: 3,205
    edited March 2013
    last 3 aholes reported
  • ddsski
    ddsski Posts: 50
    edited March 2013
    If its "power" cable, its not speaker cable and its not usually 99+% pure. You can do a bit better without going nuts. Look up Windy City 14/4. If inclined, you can double it up and have 10 gauge.
    The MAINE System
    Marantz AV7005
    2 Carver M200t's biamped, Adcom GFA 7000
    Pioneer DV-46A, Lightspeed
    Polk LSi 15's, PMC DB1+C, Polk LSi7, Sunfire True Sub II
    Samsung HP-T1254 42in Plasma
    Kubala Sosna Center wiring, DAO Kubala Sosna , Apature & Monster HDMI's
    The CT System
    Marantz AV7005
    MacIntosh MC352, Marantz MM7705w/Sig. upgrade
    Polk LSi15's, Golden Ear Technologies Sat 50's & 50C
    Kubala Sosna Speaker wire, Audioquest interconnects and assorted other goodies
