Thorens TD-166 MKII in NYC area
  • classic carl
    classic carl Posts: 662
    edited March 2013
    gdb wrote: »
    What's the general consensus here on the best method of mounting the Shure M97xE onto a vintage Thorens headshell/arm/table ? I mounted one on my stock TD-145 a while ago and have since realized that there were probably several better ways to go about doing it. Any advice is appreciated ! :smile:
    I have no idea. The Shure that came with my table was already mounted and aligned. I've yet to venture into installing a new cart on my Thorens, but may try my Sonus Gold Blue on there in the future. I'm in no hurry though. It looks different than any other table I've owned. Is your headshell or arm wand removable?
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Home Theater 5.2:
    Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
    Winter Residence 2.1 (laptop system):
    Yamaha RX-485 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
  • nspindel
    nspindel Posts: 5,343
    edited March 2013
    Mine was installed when I bought it from Frank. Fairly certain he had it done professionally.
  • gdb
    gdb Posts: 6,012
    edited March 2013
    Thanks, from what I have gathered, the Shure is a tricky one, and I probably need to do a better job. Maybe I'll consider having it done by a pro also. I might even get some diff. cartridges for two spare headshells I've got and have them all done at the same time.
