ModWright SWLP 9.0SE w/extras
SCompRacer
I also have this listed on the 'gon. Asking $2,300 there. Polkies can do better, PM me if interested. This is a great pre amp and phono stage. High current extremely low distortion design Class A tube circuit.
ModWright SWLP 9.0SE. Rated 8/10 for age only; no scratches/scrapes, non-smoking environment. Original owner, optional Blue faceplate, ModWright Signature caps (although there are a couple of Sonicaps in there), tube regulated PS (Silver face) with factory upgrade (have receipt). Reason for sale is I built a real nice dual mono balanced output DAC which required a balanced pre amp. (Dan could add XLRs to the SWLP but not make it balanced circuitry, and my amps have balanced inputs so it was time). There is a great deal of worthy praise for this pre amp with phono stage.
Includes remote, a pair of Tube World Raytheon 5687 Kuhl-Tubes, a Mullard branded 5AR4 rectifier Kuhl-Tube ($375), a new Ruby 5AR4 that came with PS upgrade, two pairs Sovtek 6C45, two pairs Sovtek 6N1P, pair of Tung Sol WA, Phillips WB, Sylvania WA. While not pictured original manual is included. The Sovteks I got from Dan as spares. The 5AR4 is a Holland black base rebranded Mullard. Similar sonics to 55-57 metal base.
Will ship in original shipping boxes. Ill also include the three isolation type footers that I also bought from Dan. I had the tubes tested at a local radio repair place. They all tested strong (100% +) on a Sencore.
NOTE: The retail price ($5,045) includes tube rectified SWLP and includes optional blue faceplate ($200) and the $400 PS upgrade. Buyer pays shipping and paypal fees, if applicable.
* MM & MC Phono Inputs with Cartridge Loading (Internal Dip switch settings)
* Five standard inputs: CD, tuner, DVD, Ht/BP, Aux.1
* Front Panel Controls Include: Mute, Power, Stereo/Mono, HT/BP (Home Theater
Bypass) and Volume control
* Remote Control Volume and Mute
TECHNICAL SPECIFICATIONS
* Tube Complement: (2) 6C45 (Sovtek), (2) 6n1P (Sovtek), (2) NOS 5687 dual triodes
* Gain: 68dB Max MC gain variable
* Stereo/Mono setting
* Variable Cartridge loading for MM/MC (50, 100, 500, 1k, 47K ohm)
* Split passive RIAA filter with zero negative feedback
* Fet-tube hybrid input and Mu* gain stages
* Output Impedance: ~600ohm
* Frequency response: 20Hz 50Khz +/-1dB
* External optional tube regulated power supply w/factory upgrade
* MWI Teflon film/foil and Metalized Oil Impregnated poly capacitors
* Volume Control: Remote control Alps motorized volume potentiometer
* Dimensions: 17"W x 12"D x 4"H (preamp)
* 8"W x 10"D X 4"H (external power supply)
Post edited by SCompRacer on
Beautiful piece of gear! GLWS2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
Sad to see it go. Rich is a great seller btw! Great to deal with and if you have questions always easy to talk to and get an answer. GLWTS!!!
Gorgeous piece...
Bump for a fabulous preamp with a phono. I have enjoyed listening to this beautiful piece with Rich. This preamp is one of the finest you will ever find at this price. And look at all the extras!!!
Buy with confidence from a first class Polkie.Carl -
Killer preamp! I had the version a step below this one and loved it.
Mods, please mark sold.
Thanks for the kind words and well wishes! From LZ IV, B side, Going to California!Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote: »Going to California! . . . . . .
With a breakin' in my heart . . . . .Carl -
someone just got a killer of a pre,,great pedigree, and loving parents!JC approves....he told me so. (F-1 nut)
Hi George! "Adult owned, responsibly driven, never taken out in snow/salt, never turned past 11 oclock.":cheesygrin:Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
The end of an era. Some sweet music passed thru that at your house, Rich.Jay
Krell rules in that house now.SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
