SDA SRS tweeter clip out
oldrocker
oldrocker Posts: 2,590
edited March 2013 in Troubleshooting
At higher volume levels, both sets of tweeters clip out, is there a page or fact sheet that describes possible reasons and solutions?
Running a crown xls1500 amp "yea I know I'll take grief for this"
Parasound 2100 pre amp. Happens at the 4-5 dial level.
Clean box pro level converter.
CD player.
Post edited by oldrocker on
    F1nut Posts: 51,944
    edited March 2013
    You're tripping the polyswitches on the crossover board. It could be because they have been tripped to many times and have become hypersenstive or your amp is clipping or both.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited March 2013
    That amp is like designed for like a PA systems? I am not knocking your amp (although it is kinda inexpensive) I am just saying that maybe the poly switch is just doing it's job and (the amp) it does not like the load these high end speakers impose.
  • oldrocker
    edited March 2013
    Yep, a pro amp "I know" but the converter is working okay. Thanks for the poly switch thing...
  • oldrocker
    edited March 2013
    Thanks. I'll pass that on to the guy looking into the reason why they clip. Just gathering info from others that might have had the same problem and hopefully hearing what causes/solutions people have figured out. THANKS again!
    Toolfan66 Posts: 18,159
    edited March 2013
    Polk no longer gives out poly switches...
    I would get rid of the polys by using a jumper or a .5 resistor. But first you need to get a better amp or your asking for trouble..
    On a plus side you will be floored on how moch better they sound without those old poly switches in them..
    F1nut Posts: 51,944
    edited March 2013
    What does that have to do with the price of tea in China?
  • oldrocker
    edited March 2013
    They also clipped with a parasound 2250 amp also at the same volume level. I do appreciate the information on possible causes and how it can be fixed. Funny thing is they still sound very good in their current condition. THANKS ALL!!
    F1nut Posts: 51,944
    edited March 2013
    The polyswitch trips as in it is a resettable fuse. Clipping is something else entirely.
    http://en.wikipedia.org/wiki/Resettable_fuse
    You need to either replace yours or remove them.
  • oldrocker
    edited March 2013
    Thank You F1, damn I wish I knew 1% of what you know. Oh well, trial and error, time and money thats my reality but it will be worth it.
    pitdogg2 Posts: 27,232
    edited March 2013
    F1 is right and I also know way to well. On my SDA's the poly switch would trip at a very low level like 20-30 wpc drove me nuts. I guess the owner before me drove them with a very cheap reciever and they must of tripped a LOT them babies were wore out. I would get more polyswitches onless you get a better amp.
  • oldrocker
    edited March 2013
    Gotta stay with the parasound 2250 for now. These speakers truly are amazing even in their condition of how good they sound. I can't say thanks enough for the advise "which I'm passing" on to my repair guy. Hopefully he'll get time soon to address the info.
    I wish I could just drop them off at Polk, leave a check and say fix em!!
  • PolkieMan
    edited March 2013
    But that would remove the eureka experience that you are going to get. :biggrin:
    I will say this I had a problem child 100 wpc Carver amp that used to make mine (polys) trip real easy changing the amp got rid of the problem.
    oldrocker wrote: »
  • oldrocker
    edited March 2013
    Crap, I just bought this amp. Oh the pains of knowing the least in these rooms!!!!
    PolkieMan wrote: »
  • PolkieMan
    edited March 2013
    Don't feel too bad that Carver TFM-15 was bought new and wasn't cheap and guess what the place I bought it from went out a business.:wink:
    oldrocker wrote: »
