Polk Trivia Question
rskarvan
rskarvan Posts: 2,374
edited June 2004 in Speakers
First off, I don't know the answer to this one. But, I am curious. I looked at the parts list for the 7B and the 7C and all the components are identical. This got me thinking. Does anybody know the difference between the Monitor 7B and the Monitor 7C?
I'm just curious. How can two different model speakers have identical replacement parts?
  • gmorris
    gmorris Posts: 1,179
    edited June 2004
    I'm surprised no body responded to this.....:confused:
    I don't know the answer either, but I'd guess that they use different cabinets.
    Take, for example, the LSi15 & the LSiC. They use the same drivers. (probably different x-over, though) So, parts would be the same, but obviosly a different speaker in every regard.
    Bob Mayo, on the keyboards. Bob Mayo.
  • danger boy
    danger boy Posts: 15,722
    edited June 2004
    i'm curious too. i have a pair of 7b's. i'd like to know the difference between the 7's, 7b's, and 7c's.
    any of the long time Polksters know the difference?
    PolkFest 2012, who's going>?
  • Pauly
    Pauly Posts: 4,519
    edited June 2004
    Ony diff i know is from the orig, the xovr was fused on the outside and the b adn c were fused on the inside..I think they made a minor improvemnt on the x over from the b to the c and upgraded the tweets, i think.
    Life without music would♭
  • Pauly
    Pauly Posts: 4,519
    edited June 2004
    either that or the orig are diff, but the replacments fit and do the trick. I recal i email I'd email Ken S @ CS if you want the real skinny.
