TL350 wall mounts / cable
Hi,
Finally got all my system together now, TL350 + PSW108 and Denon AVR-2113
Setup the fronts and sub and now onto the rear speakers.
I want to wall mount the two at the back and need some recommendations for brackets, I would like to be able to angle them in up/down and left/right so something that may work with this.
The place I want to attach them I don't seem to have a stud so they may be going straight into drywall (not the best idea) but I may have no choice.
My dealer said I can use 16 awg cable as I'm running about 50 feet to each speaker, but I may bump it to 14 awg Just to get the front speakers running he sold me some 16 awg for the fronts and it seems OK.
Would I notice any difference uping the fronts to 14
Im going to use cordmate or cordmate II to hide the cable (dont want to start feeding it into walls)
TL350s + PSW108 + Denon AVR-2113ci
I got a cheap pair on ebay for 8 bucks and they are great. I have my TL2s mounted from the ceiling angled down.My H/T:
AVR: Pioneer VSX-921-K
Front L/R: Sony Towers SS-MF600H (will be upgraded to M70's or 75T's)
Center: Polk TL2
Surrounds: Polk TL2
Rear Surrounds: Sony satellites from old HTIB (will be upgraded to TL2)
Subwoofer: Sony from old HTIB (will be upgraded to DSWPRO550wi) -
My H/T:
Center: Polk TL2
Surrounds: Polk TL2
Thanks for the picture, I shall try and track them down, they look like just the thing I need.TL350s + PSW108 + Denon AVR-2113ci
You're welcome. And you can swivel them too! I am also using 16 gauge speaker wire.My H/T:
Center: Polk TL2
Surrounds: Polk TL2
Center: Polk TL2
Surrounds: Polk TL2
Fond the mounts you have, should be with me today, so this weekend I can get it all set up :razz:TL350s + PSW108 + Denon AVR-2113ci
Awesome! Easy to mount and very flexible! Can't wait to get another pair when I get another set of the TLs.My H/T:
Center: Polk TL2
Surrounds: Polk TL2
