Safe to drive SDA CRS+ with these amps?
wellthisisnice
wellthisisnice Posts: 4
edited February 2013 in Vintage Speakers
Hi folks, is it ok to attach my SDA CRS+'s to an HK 730? And how about a Marantz 2245? I'm using the original interconnect on the speakers. Just trying to play it safe with this vintage gear. Thanks!
Post edited by wellthisisnice on
  • tophatjohnny
    tophatjohnny Posts: 4,189
    I'd say yes. A separate amp is always going to make em sing a lot better and some here swear by the tube amps, so just enjoy and upgrade as you go. The SDA effect is in a class all by itself and I sure love mine. I had the CRS+ set for a while and they are a great little speaker! BTW, welcome to the forum, It's a great one!
  • Schurkey
    Schurkey Posts: 2,122
    1. Are the amplifier sections common-ground?
    2. Are they rated to drive a 4-ohm nominal load?
  • wellthisisnice
    As opposed to integrated?
  • wellthisisnice
    Schurkey wrote: »
    2245: Probably.
    HK730: I don't know. It's twin powered, dual mono. This is really my main question. I was hoping someone might have experience with this particular pairing of amp and speakers.
    Schurkey wrote: »
    Barely, and barely. But yes. And the owner's manual for the CRS+ states a nominal impedance of 6 ohms, not 4.
    F1nut Posts: 52,000
    Like separates, it all depends on the quality. There are integrated amps that are better than separates and vice versa. That said, integrated's or separates are better than receivers.
    Dual mono would indicate that it is non-common ground and therefore cannot be used with your SDA's unless you use the AI-1.
  • Phasewolf
    Phasewolf Posts: 514
    Absolute corruption empowers absolutely.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Legacy Audio Focus SE
    Legacy Audio Silverscreen HD center
    Polk F/X500i Rears
    Parasound HCA-3500
    Sunfire Grand Cinema
    Behringer iNUKE NU6000DSP
    Pair of CraigSUB SS-18.1
  • tx_polkhead
    tx_polkhead Posts: 248
    I am using a Harman Kardon 730 'Twin Powered' with a pair of SDA CRS+'s in the bedroom set-up for the last month and a half and it sounds amazing. I guess I got lucky and didn't even think to check the common ground issue before hooking them up. 40 Watts have never sounded so good, at least not in my home. I'll admit I am in love with that contour button, HK's equivalent to a loudness button that tapers away as the volume is turned up. Contour keeps it sounding full and rich when the volume is down low. At some point I'll have to replace bulbs as most of them are burned out but for now she works and works well and that's enough for me. I'll post a picture soon.
    Polk Audio RTA 12c's, Monitor 7c, Monitor 5JR+, SDA CRS+
  • tx_polkhead
    Polk Audio SDA CRS+ (all original someday I'll do the upgrades and wonder why I took so long to do them, w/stands)
    Harman Kardon 730 Twin Power, 40 watts and 29 lbs
    Kenwood CD changer with variable output (volume remote control capability)
    Denon DP-11F needs stylus...
    DIY J-pole antenna hidden under cabinet gives me pretty good FM reception
  • wellthisisnice
    Awesome, everyone. Great forum you have here. Thanks tx_polkhead for blazing the trail!
