Another adventure
aldine
I just picked up a pair of Monitor 10As on Craigslist. Unlike the 1cs I got a few weeks ago these were not in pieces and seem to be whole. Of course I had to look inside.
What is going on with these crossovers?
Polk SDA 1C, Monitor 10A, Monitor 5jr+, RTI A3, CSI A6, TSi100, PSW505
Post edited by aldine on
Looks like they've been modded.
PoorlyLooks like they've been modded.
The 10s take pretty standard values. Looks like the used whatever they had laying aroundHome Theater/2 Channel:
dhsspeakerservice.com/ -
Looks like someone used what they have to come up with the value needed on the caps.
If they are within tolerance %, should be okay. :question:
Instead of 12uf and 34uf, it has 12.2uf and 32uf.
I think the 32uf one may be slightly at the edge of tolerance but the 12.2's are okay.
Assuming both are 16 in there.
The guy I bought them from told me they were done at a local "reputable" speaker repair place. They do sound good. Not as good as the 1Cs, of course.Polk SDA 1C, Monitor 10A, Monitor 5jr+, RTI A3, CSI A6, TSi100, PSW505
Yeah, hard to beat that good ol SDA sound!!"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
I guess "reputable" has different meanings for different people.The guy I bought them from told me they were done at a local "reputable" speaker repair place. They do sound good. Not as good as the 1Cs, of course.Home Theater/2 Channel:
I would have used proper values, and I wouldn't have used Bennics. There are better caps out there. Also, if you can solder consider replacing those original sand cast resistors with a Mills (roughly $4 each) or some other quality brand of non-inductive resistor.
It would make a fairly dramatic improvement for very little money."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Sounds like good advice.(bad pun) The parts for my 1cs should arrive today. The 10As will be next.Polk SDA 1C, Monitor 10A, Monitor 5jr+, RTI A3, CSI A6, TSi100, PSW505
