Flat screen TV's and placement of center channel speaker?
kberg
kberg Posts: 974
edited February 2013 in Speakers
Ya know, I don't know if I'm missing something here, but where the hell do you put a center channel speaker (such as a CSi40) if you just purchased a brand spanking new flat screen TV, or any TV that has about 2" or less of flat "top space"?!
I mean, say you have the latest and greatest (and thinnest) display technology and no place for a center channel to go? Even with the "matching" TV stands there is typically not enough height space between shelves for a center channel speaker, so where do you put it? Worse yet, if you're only choice for your entertainment center is in the corner of the room, THEN what do you do? Is some form of wall-mounting the only way to go? Are there wall mounting "shelf kits" available for corner systems?
Mains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688
Post edited by kberg on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited July 2005
    Wall mount / shelf - or on the floor, below (and usually angled up slightly) on a stand.
  • mantis
    mantis Posts: 17,502
    edited July 2005
    I feel your pain.
    I have the same problem with my system. My center channel is to big to fit inside my Salamander rack nice and my TV is one 3 inches deep on top. I looked at a few center channel wall mounts and haven't liked any of them. Building a custom shelf strong enough to hold the weight seems to be the way to go. In the corner will require some custom shelf building for the corner.
    There are some nice tv stands that can hold the center along with all of your gear. I don't want to spend the money on a new cabnet as I only had mine for a few years and love it.
    Salamander does however make a custom center channel add on for my stand but that would put my tv to high. It would go underneath it. It might help you out by checking out this stand.
    http://www.salamanderdesigns.com/syn/triples.jsp
    Dan
    Dan
  • kberg
    kberg Posts: 974
    edited July 2005
    Thanks, Dan. Yeah, my only option appears to be some form of custom corner shelf, as the stands in the link you provided are too wide for corner placement (between an effin' doorwall and a fireplace). Like you, I like my current cabinet, as it is only 34" wide and yet still encases my Onkyo receiver, Sony mega changer, and VCR. After looking at some big screen (50") TV's with small "base" footprints of 34", my current cabinet would work just fine.
    My CSi40 currently sits on top of my 32" Toshiba, resting on one of those "extension shelfs" that fastens to it. But that option goes away when the big screen (eventually) arrives.
    Sub: SVS 20-39 PC+
  • Early B.
    Early B. Posts: 7,900
    edited July 2005
    Is employment of a center channel speaker stand an option? It's portability may make it an enticing alternative.
    "God grooves with tubes."
  • RuSsMaN
    edited July 2005
    That's what I was hinting to above, but appeared to be a fly by.
  • mrmusicman
    mrmusicman Posts: 303
    edited July 2005
    kberg,
    I purchaced a center speaker shelf at C.C. for my tv,I think it was $40.00 and it works great.
    Outlaw 990 Processor
    Outlaw 755 Amp
    Denon 2900 dvd-sacd
    Dishnetwork HD-Dvr
    55" Sony LCD RPTV
    Lsi 9-fronts
    Lsic-center
    Rt55i- surrounds
    Velodyne cht-10 sub
    2007 Dodge Quad cab
    Kenwood Excelon KDC-X891
    JL Audio 300/V2
    Polk Audio SR 6500 - Fronts
    Polk Audio DB651 - Rear
    2 -10" Treo Subs
    Interfire IB 2600C sub amp
    Sirius Sat radio
    Ipod connection
  • bknauss
    bknauss Posts: 1,441
    edited July 2005
    Anyone know of a stand that can handle a CS1000p? :D It seems to not be a standard size...
    Brian Knauss
    ex-Electrical Engineer for Polk
  • ezc
    ezc Posts: 426
    edited July 2005
    We sold a customer some equip. recently & when we delevered I got to see his setup. He had a center chanel shelf that rested & was velcroed to the top of the set & the back of the shelf had 2 legs that was threaded to adj the hight, attached to the back via a pivot. The other end was a pad that had velcro & was velcrowed to the set. I think it was made by Sanus. The shelf looked to work very well & being adjustable able to adj the speaker angle.
  • GaryZ06
    GaryZ06 Posts: 317
    edited July 2005
    Here is where I keep my center channel....it is pointed slightly upwards.
    Panasonic 50" Plasma + Pioneer 6010
    Toshiba XA2 HD-DVD
    Panasonic BD30 Blu-Ray
    Pioneer 1014
    Polk RTi12 (front)...Polk CSi5 (center)
    Polk RTi4 (rear)...Velodyne DLS 5000-R Sub
    3 Outlaw M-200 Amps
  • Sushi
    Sushi Posts: 3
    I use a Center Stage Bracket.
    Www.centerstagebracket.com
    you can see a bunch of pictures of them on their Facebook fan page.
    https://www.facebook.com/centerstagebrackets
    They have a bunch of different sizes to suit different applications/speaker sizes. Seems to work great for lots of people including me! Here's a picture from their site:
  • ken brydson
    ken brydson Posts: 9,006
