Flat screen TV's and placement of center channel speaker?
Ya know, I don't know if I'm missing something here, but where the hell do you put a center channel speaker (such as a CSi40) if you just purchased a brand spanking new flat screen TV, or any TV that has about 2" or less of flat "top space"?!
I mean, say you have the latest and greatest (and thinnest) display technology and no place for a center channel to go? Even with the "matching" TV stands there is typically not enough height space between shelves for a center channel speaker, so where do you put it? Worse yet, if you're only choice for your entertainment center is in the corner of the room, THEN what do you do? Is some form of wall-mounting the only way to go? Are there wall mounting "shelf kits" available for corner systems?
Mains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688
Sub: SVS 20-39 PC+
Wall mount / shelf - or on the floor, below (and usually angled up slightly) on a stand.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
I feel your pain.
I have the same problem with my system. My center channel is to big to fit inside my Salamander rack nice and my TV is one 3 inches deep on top. I looked at a few center channel wall mounts and haven't liked any of them. Building a custom shelf strong enough to hold the weight seems to be the way to go. In the corner will require some custom shelf building for the corner.
There are some nice tv stands that can hold the center along with all of your gear. I don't want to spend the money on a new cabnet as I only had mine for a few years and love it.
Salamander does however make a custom center channel add on for my stand but that would put my tv to high. It would go underneath it. It might help you out by checking out this stand.
http://www.salamanderdesigns.com/syn/triples.jsp
DanDan
Thanks, Dan. Yeah, my only option appears to be some form of custom corner shelf, as the stands in the link you provided are too wide for corner placement (between an effin' doorwall and a fireplace). Like you, I like my current cabinet, as it is only 34" wide and yet still encases my Onkyo receiver, Sony mega changer, and VCR. After looking at some big screen (50") TV's with small "base" footprints of 34", my current cabinet would work just fine.
My CSi40 currently sits on top of my 32" Toshiba, resting on one of those "extension shelfs" that fastens to it. But that option goes away when the big screen (eventually) arrives.Mains: polkaudio RTi70's (bi-wired)
Sub: SVS 20-39 PC+
Remote: Logitech Harmony H688 -
Is employment of a center channel speaker stand an option? It's portability may make it an enticing alternative.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
That's what I was hinting to above, but appeared to be a fly by.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
kberg,
I purchaced a center speaker shelf at C.C. for my tv,I think it was $40.00 and it works great.Outlaw 990 Processor
Outlaw 755 Amp
Denon 2900 dvd-sacd
Dishnetwork HD-Dvr
55" Sony LCD RPTV
Lsi 9-fronts
Lsic-center
Rt55i- surrounds
Velodyne cht-10 sub
2007 Dodge Quad cab
Kenwood Excelon KDC-X891
JL Audio 300/V2
Polk Audio SR 6500 - Fronts
Polk Audio DB651 - Rear
2 -10" Treo Subs
Interfire IB 2600C sub amp
Sirius Sat radio
Ipod connection -
Anyone know of a stand that can handle a CS1000p?
It seems to not be a standard size... Brian Knauss
ex-Electrical Engineer for Polk -
We sold a customer some equip. recently & when we delevered I got to see his setup. He had a center chanel shelf that rested & was velcroed to the top of the set & the back of the shelf had 2 legs that was threaded to adj the hight, attached to the back via a pivot. The other end was a pad that had velcro & was velcrowed to the set. I think it was made by Sanus. The shelf looked to work very well & being adjustable able to adj the speaker angle.
Here is where I keep my center channel....it is pointed slightly upwards.Panasonic 50" Plasma + Pioneer 6010
Toshiba XA2 HD-DVD
Panasonic BD30 Blu-Ray
Pioneer 1014
Polk RTi12 (front)...Polk CSi5 (center)
Polk RTi4 (rear)...Velodyne DLS 5000-R Sub
3 Outlaw M-200 Amps -
I use a Center Stage Bracket.
Www.centerstagebracket.com
you can see a bunch of pictures of them on their Facebook fan page.
https://www.facebook.com/centerstagebrackets
They have a bunch of different sizes to suit different applications/speaker sizes. Seems to work great for lots of people including me! Here's a picture from their site:
