Help with AVR for RTiA7s or 9s
darkling
I'm looking to upgrade my RTiA3s with RTiA7s or 9s and will be replacing my low-end Pioneer. The home theater will be in a 15x17 foot room, hardwood but with a large wool rug. The entertainment center is centered on one 17 foot wall with doors on either side of it. The wall opposite the HT is mostly open to the kitchen--so the room is fairly open.
What AVR will be a good fit with my set-up? Will be used for movies and music--Radiohead, Massive Attack, base-heavy, mid to low tempo electronica/soundscapes and occasionally rock.
Willing to spend $500-$800 or so.
Also will be using CSiA4 and F/Xi4.
Post edited by darkling on
IMO look for a used SC series Pioneeer Elite and budget for an amp down the road...
You will definitely need an amp down the road so make sure whatever abroad you get has preoutsHome Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Honestly your better off getting a better sub and keep the a3's. No AVR in your price range will really properly power those a7s and definitely not the a9's. Those speakers have some big drivers that are gonna suck power.HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
ISF Level 2 Certified Calibrator -
Look for an older SC-07 or 37, should be close to your price range. Either will drive the A7's without issue. The A9's would require a separate amp.Political Correctness'.........defined
President of Club Polk -
Thank you all for your advice. I do think the A7s will be plenty for me.
Can anyone recommend an amp for just the A7s? -
I use a Parasound HCA1500a with mine. Sounds good and can be had used pretty reasonable. The Halo series are even better.
^^This^^ -
I just look the 07 up--awesome! Thanks!
(no soft drink pun intended) -
Heh, bringin' the funny!TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier -
I highly recommend the SC series for the A9's. I don't have an amp yet and I love how mine sounds.AVR: Pioneer Elite SC-67
Mains: Polk LSiM707
Center: Polk LSiM706c
Rear: Polk LSiM702F/X
Sub: SVS PC12 Ultra
TV: Panasonic VIERA TC-P60GT50
DVD: Xbox 360
NMT: Popcorn Hour C-200 -
+1 I run my Rti12's off an SC-35 and love the sound, still plenty of bass out of them. I cross them over at 80hz and they've never sounded underpowered, however I know a nice beefy amp would bring a lot more out of them. I'm just think you should buy the ones you want.
