Help with AVR for RTiA7s or 9s
darkling
darkling Posts: 20
edited February 2013 in Electronics
I'm looking to upgrade my RTiA3s with RTiA7s or 9s and will be replacing my low-end Pioneer. The home theater will be in a 15x17 foot room, hardwood but with a large wool rug. The entertainment center is centered on one 17 foot wall with doors on either side of it. The wall opposite the HT is mostly open to the kitchen--so the room is fairly open.
What AVR will be a good fit with my set-up? Will be used for movies and music--Radiohead, Massive Attack, base-heavy, mid to low tempo electronica/soundscapes and occasionally rock.
Willing to spend $500-$800 or so.
Also will be using CSiA4 and F/Xi4.
Post edited by darkling on
  • ken brydson
    ken brydson Posts: 9,086
    IMO look for a used SC series Pioneeer Elite and budget for an amp down the road...
  • zane77
    zane77 Posts: 1,696
    You will definitely need an amp down the road so make sure whatever abroad you get has preouts
    Two Channel
  • specd_out
    specd_out Posts: 504
    Honestly your better off getting a better sub and keep the a3's. No AVR in your price range will really properly power those a7s and definitely not the a9's. Those speakers have some big drivers that are gonna suck power.
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
    F1nut Posts: 52,301
    Look for an older SC-07 or 37, should be close to your price range. Either will drive the A7's without issue. The A9's would require a separate amp.
  • darkling
    darkling Posts: 20
    Thank you all for your advice. I do think the A7s will be plenty for me.
    Can anyone recommend an amp for just the A7s?
  • chumlie
    chumlie Posts: 8,658
    I use a Parasound HCA1500a with mine. Sounds good and can be had used pretty reasonable. The Halo series are even better.
  • ken brydson
    ^^This^^
  • darkling
    darkling Posts: 20
    I just look the 07 up--awesome! Thanks!
    (no soft drink pun intended)
  • ROHfan
    ROHfan Posts: 1,014
    darkling wrote: »
    Heh, bringin' the funny!
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
  • mu1166
    mu1166 Posts: 172
    I highly recommend the SC series for the A9's. I don't have an amp yet and I love how mine sounds.
    AVR: Pioneer Elite SC-67
    Mains: Polk LSiM707
    Center: Polk LSiM706c
    Rear: Polk LSiM702F/X
    Sub: SVS PC12 Ultra
    TV: Panasonic VIERA TC-P60GT50
    DVD: Xbox 360
    NMT: Popcorn Hour C-200
  • B Run
    B Run Posts: 1,888
    +1 I run my Rti12's off an SC-35 and love the sound, still plenty of bass out of them. I cross them over at 80hz and they've never sounded underpowered, however I know a nice beefy amp would bring a lot more out of them. I'm just think you should buy the ones you want.
