Scratch and dent vintage polk, round terminal cup aluminum plates
VR3
So that one time run of Polk plates for you crazies did not go as smooth as we could have hoped but the good news is I guess is that means there are more for you guys in a way even if they are scratched up a little.
These are separated into A/B groups. The letter and number of a SET of plates are pictured below. You will receive the plates in the picture.
I will go ahead and tell you just to be on the safe side, THESE PLATES HAVE SCRATCHES, the B plates have scratches, marring, cuts, dents.
ALL prices are + paypal 3.5% and shipping, to ship the plates should be $6.50 a pair. If you want multiple pairs, it will still be $6.50 but if for some reason it cost more we will have to collect more shipping post shipment.
All plates except two are cut for a NL2 neutrik SDA connection, if you need these connections please take that portion to email - Vr3Mods@gmail.com
You can have these drilled for four or two binding post.
The only kicker with this order is the shop also did not include the template so I can drill the holes. I will receive the template in the next batch for the original idea behind these plates meaning these plates will ship in the next 10 to 15 business days.
Here is how the pricing will work -
Polk "A" Plates - $44.00 a set
Polk "B" Plates - $36.00 a set
Vr3 "A" Plates - $30.00 a set - Still fairly scratched up
Vr3 "B" Plates - $20.00 a set (HEAVY DAMAGE, were used as tests to try to correct the issues and quality control) These are the ones that are not marked in the picture)
Polk "A" Closed (No NL2) Plates - $44.00 a set
Please let me know if you have any questions.
Plates Available -
Polk -
A
A1
A2
A3
A4
A5
A6
A7
B1
B2
B3
B4
B5
B6
AC1
Vr3 -
A
B
Plates Available -
Polk -
A
A1
A2
A3
A4
A5
A6
A7
B1
B2
B3
B4
B5
B6
AC1
Vr3 -
A
B
Post edited by VR3 on
Plate sets A6 and A7 have been spoken for.
This leaves -
Polk -
A
A1
A2
A3
A4
A5
B1
B2
B3
B4
B5
B6
AC1
Vr3 -
A
B- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
No interest in the round plates...
Just a FWIW, if you do not want a damaged plate - I am down for going outside with the sander and sanding these bad boys down... they do not have to say Polk!
I don't know, unless you are really "anal", most of those look to be in very good shape as is!
A1 has been spoken for -
This leaves -
Polk -
A
A2
A3
A4
A5
B1
B2
B3
B4
B5
B6
AC1
Vr3 -
A
Bump!
I can drill these to accommodate Cardas and Vampire post as well!
Please put me down for VR3 A which should be 30 + 6.50..right?Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
Hey Michael
I just now! saw this...
Shoot me an email at Vr3Mods@gmail.com
Polk -
A
A2
A3
A4
A5
B1
B2
B3
B4
B5
B6
AC1
Vr3 -
Gentleman! :-P
Mid week bump!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Here is what is still available...
Polk Engraved -
A2
A3
B2
B6
B5
A5
B3
B4
VR3 engraved -
A2 SOLD -
Here is current availability -
Polk Engraved -
A3
B2
B6
B5
A5
B3
B4
VR3 engraved -
B
Thanks!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Polk Engraved -
B2
B5
B3
B4
VR3 engraved -
B
I'm not sure what is for what, so I will ask. Do you have a set to fit 1.2TL's??Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
They all fit a 1.2TL
But you will have to change over the SDA to a NL2 connection which I have available...
Mine are currently set up with 6 connectors. 4 are for amp, 2 for sad cable. What do I need to do??Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Please let me know as I really need to replace the stock cracked ones.......Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I will take B2, pm in a min.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
What is currently left -
Polk Engraved -
B5
B3
B4
VR3 engraved -
B
I received these a couple days ago, look better than the pic to me.. Very pleased. Thank you much!!Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Glad you liked them!!
Thanks again- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
