what receiver for tsi300
gonzo64
gonzo64 Posts: 39
edited February 2013 in Electronics
im looking to buy a receiver ..just want to know what would work with what i got.. tsi300 fronts ..cs10 center...psw10 sub and r150s for the rear... thanks........
Post edited by gonzo64 on
    edited January 2013
    Pretty much anything under the sun would work, those speaks are pretty easy to drive. Thing is, think about what you might want to upgrade to as far as speakers go in the future so don't limit yourself in a entry level receiver. Find one with all the goodies you want and pre outs to be able to add an amp down the road if you need to.
  • pearsall001
    pearsall001 Posts: 5,384
    edited January 2013
    gonzo64 wrote: »
    How much coin did you plan on spending? It's best for a recommendation to know budget concerns.
  • gonzo64
    gonzo64 Posts: 39
    edited January 2013
    im thinking 500 or so
  • seabeerob213
    seabeerob213 Posts: 1,843
    edited January 2013
    check accessories for less for an onkyo 809
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited January 2013
  • gonzo64
    gonzo64 Posts: 39
    is onkyo a good brand....i didnt think it was so great....i could be wrong tho.......
  • seabeerob213
    For the price they have a bit more features than the others, from what i've heard they have problems witht the HDMI boards if you move stuff alot, causing cables to be repeatiedly installed and removed, or if heavier cables are used for HDMI devices. As someone who is looking to get a legitimate set up, i would think you will care for your gear very well and these problems shouldnt arise if you heed all neccesary precautions. From the couple i have heard, the were fairly neutral sounding recievers, not too bright, but not very warm either, any amp that you add to it would change that to match the amp. whatever you pick, besure you give it some room to breathe and use power protection and good cables and wires, you dont have to spend a fortune, just get good conductivity, shieliding when applicable, and good solid connections. And now for the most important part, enjoy your system!
