what receiver for tsi300
gonzo64
im looking to buy a receiver ..just want to know what would work with what i got.. tsi300 fronts ..cs10 center...psw10 sub and r150s for the rear... thanks........
Post edited by gonzo64 on
Pretty much anything under the sun would work, those speaks are pretty easy to drive. Thing is, think about what you might want to upgrade to as far as speakers go in the future so don't limit yourself in a entry level receiver. Find one with all the goodies you want and pre outs to be able to add an amp down the road if you need to.HT SYSTEM-
lsi 9's -
How much coin did you plan on spending? It's best for a recommendation to know budget concerns."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
im thinking 500 or so
check accessories for less for an onkyo 8092 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know "WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA
is onkyo a good brand....i didnt think it was so great....i could be wrong tho.......
For the price they have a bit more features than the others, from what i've heard they have problems witht the HDMI boards if you move stuff alot, causing cables to be repeatiedly installed and removed, or if heavier cables are used for HDMI devices. As someone who is looking to get a legitimate set up, i would think you will care for your gear very well and these problems shouldnt arise if you heed all neccesary precautions. From the couple i have heard, the were fairly neutral sounding recievers, not too bright, but not very warm either, any amp that you add to it would change that to match the amp. whatever you pick, besure you give it some room to breathe and use power protection and good cables and wires, you dont have to spend a fortune, just get good conductivity, shieliding when applicable, and good solid connections. And now for the most important part, enjoy your system!2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know "WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA
