AI-1 1000va Questions
Drenis
Drenis Posts: 2,871
edited February 2013 in DIY, Mods & Tweaks
Curious what bolt you members used to secure your transformer to one of Larry's cases?
I'll be putting mine together soon.
Also, is there mention somewhere regarding how to properly wire the transformer?
Post edited by Drenis on
  • thsmith
    thsmith Posts: 6,082
    F1nut Posts: 51,767
    Use non-magnetic hardware, I used stainless steel.
    Yellow/Red - right pin
    Black/Orange - right blade
    Grey/Brown - left pin
    Blue/Violet - left blade
    heiney9 Posts: 25,432
    I have a question. My SDA 1C's were originally pin/blade and the IC has been modified by using a banana plug and a Vampire input jack so the blade side is no longer hooked up. Can I just run the appropriate connection from each side of the transformer to the negative speaker terminal? That achieves the same effect as changing the IC connector and re-wiring internally, correct?
  • Drenis
    Drenis Posts: 2,871
    thsmith wrote: »
    Thanks for that link. I did look on there but may have missed it. Evidently again as I just checked. That's what semi prompted my post.
    Thanks!!!!
    Exactly what I was looking for. And good tip on the stainless hardware.
    Toolfan66 Posts: 18,057
  • thsmith
    heiney9 wrote: »
    If I understand correctly, that is what I did as i had went to cardas BP for my IC cable.
  • drumminman
    drumminman Posts: 3,396
    I had a tough time finding the proper size stainless steel bolt when I was assembling mine. I finally found one at a marine hardware store on the coast, but probably any good size place that sells boats, etc. would have a good selection.
    Re: connecting the "blade" part of the SDA cable to the negative speaker terminal, that's what I did too. Works great!
  • Drenis
    Drenis Posts: 2,871
    drumminman wrote: »
    Marine? Boats? Woah... I was just going to go to my local Home Depot/lumber store to find something.
    What size of bolt did you use?
    F1nut Posts: 51,767
    Home Depot doesn't have stainless steel bolts. I got mine at the local Ace Hardware. The size I used was 5/16-18 x 3.5 inches.
  • nspindel
    nspindel Posts: 5,343
    Don't recall the size, I just matched the size of the bolt that came with the 800va transformer. Got stainless steel from the local hardware store.
  • Moose68Bash
    Moose68Bash Posts: 3,843
    F1Nut,
    What are the consequences or drawbacks to using a standard bolt? I have two boxes assembled, and I used standard (Home Depot) bolts in both.
    Do I need to change them out ASAP?
    I can access SS hardware from Jamestown Distributors on the Internet, if it isn't available in a local hardware or marine supply store.
    F1nut Posts: 51,767
    The magnetic field would most likely be affected by steel hardware.
    pitdogg2 Posts: 27,045
    Also not all Stainless is non-magnetic so check with a magnet. Most stainless made overseas IS magnetic. so double check.
  • drumminman
    I took a refrigerator magnet to the hardware store - guarantees you buy the correct SS bolt :wink:
  • drumminman
    From a quick google search non magnetic SS formulations includes 18-8 (most variations), 304 & 316.
    Aluminum bolts 3/8-16
    I drilled out the center hub of the transformer. Not going to hurt it any..
  • Drenis
    Drenis Posts: 2,871
    Different selection in our stores. However, there are lots of places to go for hardware.
    Thanks for listing bolt size guys. Fridge magnet is a great tip...
  • Moose68Bash
    Just ordered stainless steel (18/8) bolts, nuts and washers from <www.boltdepot.com>.
    They have a great selection of all sorts of fasteners, and its less expensive than driving 15 miles to the nearest REAL hardware store.
