AI-1 1000va Questions
Drenis
Curious what bolt you members used to secure your transformer to one of Larry's cases?
I'll be putting mine together soon.
Also, is there mention somewhere regarding how to properly wire the transformer?
the schematic is on DKs page, let me take a look.\
http://www.polkaudio.com/forums/showthread.php?129829-The-AI-1-Dreadnought-Project-Pt.2-Upgrade-to-1000VA-TransformerSpeakers: SDA-1C (most all the goodies)
Use non-magnetic hardware, I used stainless steel.
Yellow/Red - right pin
Black/Orange - right blade
Grey/Brown - left pin
Blue/Violet - left blade -
I have a question. My SDA 1C's were originally pin/blade and the IC has been modified by using a banana plug and a Vampire input jack so the blade side is no longer hooked up. Can I just run the appropriate connection from each side of the transformer to the negative speaker terminal? That achieves the same effect as changing the IC connector and re-wiring internally, correct?
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Thanks for that link. I did look on there but may have missed it. Evidently again as I just checked. That's what semi prompted my post.Use non-magnetic hardware, I used stainless steel.
Thanks!!!!
Exactly what I was looking for. And good tip on the stainless hardware. -
If I understand correctly, that is what I did as i had went to cardas BP for my IC cable.Speakers: SDA-1C (most all the goodies)
I had a tough time finding the proper size stainless steel bolt when I was assembling mine. I finally found one at a marine hardware store on the coast, but probably any good size place that sells boats, etc. would have a good selection.
Re: connecting the "blade" part of the SDA cable to the negative speaker terminal, that's what I did too. Works great!"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
drumminman wrote: »I had a tough time finding the proper size stainless steel bolt when I was assembling mine. I finally found one at a marine hardware store on the coast, but probably any good size place that sells boats, etc. would have a good selection.
Marine? Boats? Woah... I was just going to go to my local Home Depot/lumber store to find something.
What size of bolt did you use? -
Home Depot doesn't have stainless steel bolts. I got mine at the local Ace Hardware. The size I used was 5/16-18 x 3.5 inches.
Don't recall the size, I just matched the size of the bolt that came with the 800va transformer. Got stainless steel from the local hardware store.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
F1Nut,
What are the consequences or drawbacks to using a standard bolt? I have two boxes assembled, and I used standard (Home Depot) bolts in both.
Do I need to change them out ASAP?
I can access SS hardware from Jamestown Distributors on the Internet, if it isn't available in a local hardware or marine supply store.Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
The magnetic field would most likely be affected by steel hardware.
Also not all Stainless is non-magnetic so check with a magnet. Most stainless made overseas IS magnetic. so double check. -
I took a refrigerator magnet to the hardware store - guarantees you buy the correct SS bolt
From a quick google search non magnetic SS formulations includes 18-8 (most variations), 304 & 316."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Different selection in our stores. However, there are lots of places to go for hardware.
Thanks for listing bolt size guys. Fridge magnet is a great tip... -
Just ordered stainless steel (18/8) bolts, nuts and washers from <www.boltdepot.com>.
They have a great selection of all sorts of fasteners, and its less expensive than driving 15 miles to the nearest REAL hardware store.Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
