Considering the RTiA7
gotscreen
I have read these speakers love lots of power. I plan on powering them with Emotiva UPA 700. This is rated at 80 watts at per channel at 8 ohms. I have a 7.1 set up so I cannot bi-amp the front speakers. I want to know what others have experience with a full range of power outputs.
Post edited by gotscreen on
That would probably be about the minimum power you would want to use but should sound okHome Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Are you using it for home theater only or music as well?
Plan on something else, such as a Pioneer Elite SC TOTL series AVR, which will easily outperform that amp.Political Correctness'.........defined
President of Club Polk -
I have a pair and although right now they are connected to a Yamaha AVR and sound good, when connected to a Carver TFM-25 they sounded fantastic. The Carver is rated around 225 watts rms. On the other hand they also sounded superb with my rebuilt Eico ST-70 (not to be confused with Dynaco with the same model number) tube integrated rated at between 35 and 40 watts RMS per channel. The key to making them sound up to their full potential is a high quality amp, be that solid state or tube.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
They sound great with my 810 running 5.1. No extra power needed...yet!
Anaheim Hills CA,
HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
I have a pair running off a Parasound new classic 2125 that sound good.
I have them connected vertically with a pair of Cerwin Vega CV-1800 running off a Nad 1155 Preamp.
CAN YOU HEAR THEM NOW!!!
Long break in time but worth the wait as they get AWESOMER the more you use them.Current Configurations
Master Bed room:
Polk Audio RTI A7
Nad 1155 Preamp
Nad Stereo Tuner 4155
2 Cerwin Vega CV-1800
Panasonic 42 inch
PS3
Apple Ipad 3
Pure i-20
Alienware X51
DBX 234xs
Living Room:
Bose 301's
Nad 1155 Preamp
Nad 2200 Power Amp
Nad Stereo Tuner 4130
Panasonic 50 inch
Sony DVD Player
Apple iTouch 4 -
yeah Cerwin Vega makes everything AWESOMER :rolleyes:2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
If you have a sub "carrying" the bottom, below 50-60hz, & your Emo amp is robust, handle 4 ohms, you may be OK.
On the hand if that Pio AVR can deliver better SQ as someone suggested earlier...
My $.02, TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
I'm a noob that started with the RTiA7's as my first set of speakers.
I'm powering them with my Yamaha RX-A2010 and think they sound great. Not sure how much "better" they would sound if I added an amp, but I'm considering it.Polk Fronts: RTi A7's
Polk Center: CSi A6
Polk Surrounds: FXi A6's
Polk Rear Surround: RTi4
Sub: HSU VTF-3 (MK1)
AVR: Yamaha RX-A2010
B&K Reference 200.7
TV: Sharp LC-70LE847U
Oppo BDP-103 -
My RTI10's opened up quite a bit when i switch from my NAD 7400 (100 wpc cont, 370 dynamic) to the 7600 (150 wpc cont, 500 dynamic), so i imagine you won't get the most out of those's a7's with 80 wpc. It will be good, just not up to potential.
