Considering the RTiA7
gotscreen
gotscreen Posts: 1
edited February 2013 in Electronics
I have read these speakers love lots of power. I plan on powering them with Emotiva UPA 700. This is rated at 80 watts at per channel at 8 ohms. I have a 7.1 set up so I cannot bi-amp the front speakers. I want to know what others have experience with a full range of power outputs.
Post edited by gotscreen on
  • zane77
    zane77 Posts: 1,696
    edited January 2013
    That would probably be about the minimum power you would want to use but should sound ok
    Two Channel
  • gfong
    gfong Posts: 1,079
    edited January 2013
    Are you using it for home theater only or music as well?
    F1nut Posts: 52,301
    edited January 2013
    Plan on something else, such as a Pioneer Elite SC TOTL series AVR, which will easily outperform that amp.
  • Fongolio
    Fongolio Posts: 3,516
    edited January 2013
    I have a pair and although right now they are connected to a Yamaha AVR and sound good, when connected to a Carver TFM-25 they sounded fantastic. The Carver is rated around 225 watts rms. On the other hand they also sounded superb with my rebuilt Eico ST-70 (not to be confused with Dynaco with the same model number) tube integrated rated at between 35 and 40 watts RMS per channel. The key to making them sound up to their full potential is a high quality amp, be that solid state or tube.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • gce
    gce Posts: 2,158
    They sound great with my 810 running 5.1. No extra power needed...yet! :wink:
    Anaheim Hills CA,
    HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
  • pah
    pah Posts: 12
    I have a pair running off a Parasound new classic 2125 that sound good.
  • mralexny
    mralexny Posts: 39
    I have them connected vertically with a pair of Cerwin Vega CV-1800 running off a Nad 1155 Preamp.
    CAN YOU HEAR THEM NOW!!! :)
    Long break in time but worth the wait as they get AWESOMER the more you use them.
    Current Configurations
    Master Bed room:
    Polk Audio RTI A7
    Nad 1155 Preamp
    Nad Stereo Tuner 4155
    2 Cerwin Vega CV-1800
    Panasonic 42 inch
    PS3
    Apple Ipad 3
    Pure i-20
    Alienware X51
    DBX 234xs
    Living Room:
    Bose 301's
    Nad 1155 Preamp
    Nad 2200 Power Amp
    Nad Stereo Tuner 4130
    Panasonic 50 inch
    Sony DVD Player
    Apple iTouch 4
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    yeah Cerwin Vega makes everything AWESOMER :rolleyes:
  • gp4jesus
    gp4jesus Posts: 2,019
    If you have a sub "carrying" the bottom, below 50-60hz, & your Emo amp is robust, handle 4 ohms, you may be OK.
    On the hand if that Pio AVR can deliver better SQ as someone suggested earlier...
    My $.02, Tony
    *all connected w/Premiere ICs
  • badchad
    badchad Posts: 348
    I'm a noob that started with the RTiA7's as my first set of speakers.
    I'm powering them with my Yamaha RX-A2010 and think they sound great. Not sure how much "better" they would sound if I added an amp, but I'm considering it.
    Polk Fronts: RTi A7's
    Polk Center: CSi A6
    Polk Surrounds: FXi A6's
    Polk Rear Surround: RTi4
    Sub: HSU VTF-3 (MK1)
    AVR: Yamaha RX-A2010
    B&K Reference 200.7
    TV: Sharp LC-70LE847U
    Oppo BDP-103
  • plainoledave
    plainoledave Posts: 408
    My RTI10's opened up quite a bit when i switch from my NAD 7400 (100 wpc cont, 370 dynamic) to the 7600 (150 wpc cont, 500 dynamic), so i imagine you won't get the most out of those's a7's with 80 wpc. It will be good, just not up to potential.
