Need more advice about speakers
rebuy
rebuy Posts: 695
edited January 2013 in Speakers
Ok, I bought a New H-K 1565.70 WPC (stereo) with 25 amp HCC.
It's an AVR but can be used for stereo.
I bought it because I dislike the Onkyo for music.
I can live with the Onkyo for movies and TV.
Really I was thinking about using the H-K with
a pair of LSI 7's for 2 Channel music, would that work ?
I would not try it with 9's.
It's either that or buy one more pair of RTI's.
Post edited by rebuy on
  • steveinaz
    steveinaz Posts: 19,545
    edited January 2013
    It depends on 2 things; 1. How loud do you listen?; 2. Is the AVR rated for 4ohm speakers?
  • rebuy
    rebuy Posts: 695
    edited January 2013
    Steve we really don't listen very loud since we have a small room.
    It's an 8 ohm H-K but If I ran it just in stereo for music would
    it be Ok for a small 4 ohm speaker like the LSI 7 ?
    Every once in a while I might crank it up to 80 db or so
    but not ear splitiing.
    I would like to have a speaker that produces Great sound at low
    to moderate volumes.
    The H-K will arrive in two days and I have not heard the RTI'4 I have
    with a H-K for music, it has to be better than my Onkyo for music.
  • rooftop59
    rooftop59 Posts: 8,121
    edited January 2013
    you'll be fine, but they won't sing like their meant to. The LSi7s are actually closer to 6 ohms if you look at every professional bench test. I think Polk just wanted to keep the whoel series consistent. I have run three 7s and two easier to drive surorunds off an HK avr 630 (admittedly more powerful than what you bought) for movies at some pretty decent volumes (not quire reference) and it sounded good. But on an older nad 317 integrated or an Adcom gfa 545 those 7s really come alive and sound much better. But you will still be able to appreciate the sweet sound with what you have.
    Game Room 5.1.4:
    Bedroom 2.1
  • steveinaz
    edited January 2013
    ^Agree. If you listen at modest levels I think you'll be fine, just give the AVR plenty of ventilation/space.
  • rebuy
    rebuy Posts: 695
    edited January 2013
    Thanks for the info guys. Will the Lsi7's be that much better than RTI 4's for Music on a H-K ?
  • vcwatkins
    vcwatkins Posts: 1,993
    edited January 2013
    I'd take a short ride to get Falconcry's 7c's. Pleasing sound (better than LSi7 IMO), easy on the amp and wallet.
    Craig
  • vcwatkins
    edited January 2013
    OK, a not-so-short ride. I'd still get 'em.
  • rooftop59
    edited January 2013
    rebuy wrote: »
    I would say unequivocally yes. but it's a different sound and which you prefer is a matter of personal preference. The rti4s are a little leaner in the bass, a little brighter up top (as sterephile's test bench demonstrates and listening confirms) and more forward sounding. The Lsis have a Sweet airy and extended high range, and are laid back. So it's just a question of which characteristics you prefer.
    Game Room 5.1.4:
    Bedroom 2.1
  • steveinaz
    edited January 2013
    vcwatkins wrote: »
    Craig
    ^Good advice.
