Need more advice about speakers
Ok, I bought a New H-K 1565.70 WPC (stereo) with 25 amp HCC.
It's an AVR but can be used for stereo.
I bought it because I dislike the Onkyo for music.
I can live with the Onkyo for movies and TV.
Really I was thinking about using the H-K with
a pair of LSI 7's for 2 Channel music, would that work ?
I would not try it with 9's.
It's either that or buy one more pair of RTI's.
Post edited by rebuy on
It depends on 2 things; 1. How loud do you listen?; 2. Is the AVR rated for 4ohm speakers?Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Steve we really don't listen very loud since we have a small room.
It's an 8 ohm H-K but If I ran it just in stereo for music would
it be Ok for a small 4 ohm speaker like the LSI 7 ?
Every once in a while I might crank it up to 80 db or so
but not ear splitiing.
I would like to have a speaker that produces Great sound at low
to moderate volumes.
The H-K will arrive in two days and I have not heard the RTI'4 I have
with a H-K for music, it has to be better than my Onkyo for music. -
you'll be fine, but they won't sing like their meant to. The LSi7s are actually closer to 6 ohms if you look at every professional bench test. I think Polk just wanted to keep the whoel series consistent. I have run three 7s and two easier to drive surorunds off an HK avr 630 (admittedly more powerful than what you bought) for movies at some pretty decent volumes (not quire reference) and it sounded good. But on an older nad 317 integrated or an Adcom gfa 545 those 7s really come alive and sound much better. But you will still be able to appreciate the sweet sound with what you have.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
^Agree. If you listen at modest levels I think you'll be fine, just give the AVR plenty of ventilation/space.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Thanks for the info guys. Will the Lsi7's be that much better than RTI 4's for Music on a H-K ?
I'd take a short ride to get Falconcry's 7c's. Pleasing sound (better than LSi7 IMO), easy on the amp and wallet.
CraigBeach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
OK, a not-so-short ride. I'd still get 'em.Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
I would say unequivocally yes. but it's a different sound and which you prefer is a matter of personal preference. The rti4s are a little leaner in the bass, a little brighter up top (as sterephile's test bench demonstrates and listening confirms) and more forward sounding. The Lsis have a Sweet airy and extended high range, and are laid back. So it's just a question of which characteristics you prefer.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Craig
^Good advice.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
