Where are people getting their speaker spikes these days
13»
  • allstock
    allstock Posts: 136
    edited January 2013
    Too high for the proper tweeter height. The third tweeter down should be at ear level when seated.
    It's within an inch, so I guess it was about an inch or so low with the stock feet. Perhaps the pic is misleading, they are 3.5" higher than stock. Either way, sound is much improved with the "Tall" spikes in my set-up.
    Two Channel-SDA SRS 1.2tl's,modded, Cambridge Audio 851w amps(2),Cambridge 851e pre, VPI Scout 1.1 tt, Moon audio phono pre,oppo bd105.
    HT-Denon avr3808ci,Carver a-753x,Panasonic ae4000 projector,120" screen,ps3,wii console w/full rockband,Panamax conditioner,dbx120 subharmonic synthesizer,jvc dvd-a player, Polk RTi12 mains,Polk CSiA6 centre, Energy ES-18xl sub,two custom 10" powered subs, Def Tech bp2x surrounds(4),Paradigm monitors-rear(2)
    F1nut Posts: 51,763
    edited January 2013
    thsmith wrote: »
    janmike, what about getting a group buy going. I would take 2 sets of 8. I have not found a better spike and at their price.
    Grant was stocking his spikes in 1/4-20 for a while because of the all the requests from Polkies, then after he started to stock them, the demand disappeared. At least that is how it was explained to me.
    F1nut Posts: 51,763
    edited January 2013
    allstock wrote: »
    You must be very tall or have high seating. 3.5 inches is just way too high.
  • allstock
    allstock Posts: 136
    edited January 2013
    Ya a bit of both. At 17' listening distance I would think that 2-3" inches in height should not make a difference. If it does it would indicate a VERY small sweet spot indeed. I will listen with a phone book under me for a few sessions and see if it "helps". lol
    I got the tape measure out, btw, and my ears are in fact 2" below the 3rd tweeter down. I have never heard that on the big sda's that your ear is supposed to be at "exactly" ear level of the 3rd tweeter.
  • zingo
    zingo Posts: 11,258
    edited January 2013
    Just got my black chrome spikes from Oregondv.com and will be installing them tonight.
  • ken brydson
    ken brydson Posts: 9,002
    edited March 2013
    Did you end up finding good spikes for your 90"s?
  • thsmith
    thsmith Posts: 6,082
    edited March 2013
    I did Ken, I thought they might be to small but they are perfect for the 90s in my room but the carpet is not very deep so YMMV.
    http://www.avoutlet.com/index.php?dispatch=products.view&product_id=1575
  • pablo_rodz
    pablo_rodz Posts: 331
    edited March 2013
    Does anyone know the thread size for RtiA9's?
    HT:
    Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
    Living Room:
    Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7
    F1nut Posts: 51,763
    edited March 2013
    1/4-20
  • ken brydson
    edited March 2013
    thsmith wrote: »
    Did they fit the stock threads?
  • thsmith
    edited March 2013
    LS90 threads are 1/4 -20 which required me to buy the 6mm to 1/4 - 20 adapters.
  • Lost240
    Lost240 Posts: 176
    edited March 2013
    What about spike shoes?
