Pot for Sunfire
SDA1C
SDA1C Posts: 2,072
edited January 2013 in Electronics
'ello,
Does anyone know off the top of their head what the part numbers for the volume pot on the TGP3 is?
At risk of turning this to a cable debate...what changes will the different pot materials create?
Thanks, Dan
Too much **** to list....
Post edited by SDA1C on
    Toolfan66 Posts: 18,364
    edited January 2013
    I will give you some pot for a sunfire..
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2013
    You don't have enough pot LOL
    edited January 2013
    Now you don't know that!!:cheesygrin:
  • decal
    decal Posts: 3,205
    edited January 2013
    You don't have enough Sunfire for my pot !!!!!!
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2013
    On a serious note...The volume pot went **** up on my pre. Where's the best place to get one and htf do you know which one to get?
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2013
    decal wrote: »
    Only one way I know of to know whether or not the pot was worth it.
    edited January 2013
    decal wrote: »
    you don't have enough sunfire for my pot !!!!!!
    lol!!
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited January 2013
    I'll trade a lid for it!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2013
    No Pot knowledge here eh? Well at least none by anyone that isn't too paranoid to divulge?
  • Drenis
    Drenis Posts: 2,871
    edited January 2013
    FWIW I tried to clean the pot in my pre to fix it and now it no longer works :razz: So definitely not afraid to divulge.
  • decal
    decal Posts: 3,205
    edited January 2013
    My pot needs no cleaning.
  • ken brydson
    ken brydson Posts: 9,086
    edited January 2013
    I did not inhale....
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2013
    Turns out
    it isn't one of these...
    It was one of these...
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2013
    No pot at all in fact. It is called a rotary encoder for those, like myself, that did not know before. I am assuming not many do or there would be more than 9 hits on "rotary encoder" in the search. Either way...good info. I guess i never tried to turn it all the way up, or down, and thus was unaware that it has no stopping point. Now where did it put those static slippers and ankle strap?
    One a lighter note...the wife did say, "Well, You did buy it used. Probably time to start looking for a replacement"!
    She did this with the washer and dryer about 2 months ago...a 5 dollar bushing took a **** and bought a new set before I could fix it (read- brought a new set home that night). I fixed the washer for $7.89 and about 15 minutes of my time then sold them to a college student in need of a used set. They were only 3 years old for crying out loud! Ah well, she wants nice things too so I don't say much when she does go shopping. I bet she will have something to say about the next pre and it's dent in ye ol' pile 'o gold than her washer and dryer did muahah!
  • Drenis
    Drenis Posts: 2,871
    edited January 2013
    Thats what I have in my pre. One very identical to what you posted.
    Did you just buy a replacement? Any idea as to what the goop is used inside these? Mine was not smoothly going up or down. However I cleaned mine and left NO residue of whatever gunk was in there.
    Rotary Encoder... interesting.
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2013
    I am not sure the lube is for anything beyond the shaft lol. the contacts were dry and I assume they need to stay that way based on the closeness of the fingers on the pickup. Any dielectric grease at all could bridge those contacts. If that's bad? I don't know. To be forthcoming here...I am about to sell the oppo and 425 and buy the sc68 and the elite Bdp. But haven't talked the wife into the hiatus of the main rig till they sold.
  • erniejade
    erniejade Posts: 6,321
    edited January 2013
    "the lube is for anything beyond the shaft "
    Giggity
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2013
    All back together and singing again. Yea!
    SCompRacer Posts: 9,278
    edited January 2013
    Good job!
    I use one of them rotary encoders on my Arduino controlled DIY DAC to cycle through the menus. I added hardware debounce and believe it works better than software debounce. (Hardware cancels the noise spikes created by turning/making selections). Encoders have different specs or feel. That is cycles per turn, can have a built in switch and rotary clicks. My personal fav is a discontinued Panasonic EVQ-WTEF2515B. Bourns PEC11 is a close second.:cheesygrin:
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2013
    Thanks!
    I used the current version of what is considered an ALPS 043n. With the old one I could hear a slight blip when changing the channels and raising volume with the remote but didn't recognize it as an encoder issue. That blip was entirely eliminated and the noise floor seemed to soften but I won't attest to it being more than my perception. Just a first reaction and what I noticed. I also noticed a decrease in radio static for what ever reason. I have read it is possible bu I cannot explain the why . There are 24 detents in the one I used but for the tightness and smoothness of the dial you would think it wan infinite. I did read the thread about your DIY DAC. I bet that piece sounds awesome!.
    edited January 2013
    I think I posted this in my DAC thread. This is a scope print of what happens when an encoder is turned. Software debounce is where they write delay in the code, hardware uses parts to suppress it.
    rotaryencoder-bounce.jpg?w=595
    Thanks for the kind words. The DAC is the closest I ever heard digital sound truly analog. There are many levels of DIY DAC's to fit any budget. Aside from power and analog stages, focus is on the lowest jitter input, sometimes by reclocking the source clock at destination. For folks that don't want to DIY, look into a good USB to DDC (Digital to Digital Converter) that reclocks the SPDIF signal before passing it off to a DAC. The better the source clock, the better the digital SQ.
