The truth about matching centers to fronts?
CarlosD
CarlosD Posts: 21
edited January 2013 in Speakers
First let me thank everyone who's posted info and reviews on different speakers on this forum. Based on what I've read (and my budget) I just put in an order today on a pair of TSI400's for my new HT fronts (replacing a really cheap and small and old pair of Polk R1 bookshelfs). I'm really looking forward to the extra power and definition that the TSIs will deliver. Now, of course, I have to think about how well balanced the system is.
Evidently, the best matching current center for the new fronts would be the CS10 or CS20. However, only a couple-three years ago I purchased the CSi3 center channel, which I've been very happy with. So, my question today is: Would there be a noticeable difference between the CSi3 and either/both of these newer models? I seriously doubt it. The specs on the CSi3 and CS10 are very close, with maybe the 'sensitivity' rating being the biggest difference (89 for the CSi3 vs 91 for the CS10). But I have a hard time believing that my enjoyment of my system would be worth the extra expense.
By the way, I'm running a Sony AVR, the STR-DH810, with 110 watts per channel, and the Polk PSW110 sub. Interested in all thoughts. Thank you!
Carlos
Audio: Polk LS70
Home Theater: Polk TSI 400 Fronts, CS10 center, R1 surrounds, PSW110 subwoofer
Post edited by CarlosD on
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2013
    Let your ears be the judge. If you like it and it sounds good to you keep it. If not, then get a matching center. None of my speakers match and I think my system sounds great. There are no hard fast rules to the enjoyment of audio. Let your ears and common sense be your guide.
    F1nut Posts: 51,996
    edited January 2013
    Timbre matching, Google it.
  • Polka_sound
    Polka_sound Posts: 51
    edited January 2013
    Another thing to look for is if the speakers cones and woofers are cut from the same speaker fabric
  • CarlosD
    CarlosD Posts: 21
    edited January 2013
    Thanks folks.
    Re the timbre-matching comment, I should have mentioned that I'm not a stranger to the concept. In fact, I should have made this text (from the vintage products page for the CSi3) part of the original post: "Timbre-matched to fit into any Polk Audio home theater or multi-channel music system for a more realistic, more seamless surround sound environment." No doubt that marketing copy was written before the TSI line had hit the market. Could this line be so different that the CSi3 claim no longer applies?
    Cfrizz, I think I'm with you. But the CS10 is only $110 right now in a few places. Hmmm...
    Carlos
    Audio: Polk LS70
  • mantis
    mantis Posts: 17,558
    edited January 2013
    I never ever upgrade any speakers without matching them to the rest of my system.If I buy new fronts then I also buy the matching center and sell off the old one.
    In your case here I'm willing to bet it's very close to being right. If thats good enough for you, then stick with it.
    Dan
  • Geoff4rfc
    Geoff4rfc Posts: 2,955
    edited January 2013
    I agree with all answers here.
    I was once in the same boat as you as I upgraded my Monitors to RTiA's. I obtained my A9's while still using the CS2. I was under the impression that it was going to be "good enough" or "close enough".
    During a certain movie, the dialog traveled from the L to C to R speakers with three different speakers. The difference was clear as a bell. When I purchased the CSiA6, I played the movie again and then fully understood the importance of timbre matching.
    Your mileage may vary.
    One other point I'd like make, it would behoove you to audition the CS10 next to the CS20. Just because it's cheaper doesn't make it a better deal.
    I demoed them side by side and the CS20 left the CS10 sound like it was weak and straining to keep up. Your Center channel is the "strong" link in your speaker system, I wouldn't skimp out on it, go big.
    Set up: 11.2 HT + 2ch
  • Mon40CSMM10
    Mon40CSMM10 Posts: 161
    edited January 2013
    Well, I've recently experimented with mixing Pioneer CS-G203 front speakers with a Polk Audio CSM center speaker and Polk Audio Monitor 40 surround speakers, plus a Polk Audio PSW110 subwoofer.
    All I did was a calibrate each speaker to near a 75 dBC peak level. Sounds very good to me. Also, due to the CS-G203 speakers having a range down to 40 Hz, I am using a 50 Hz crossover rather than an 80 Hz crossover often recommended by home theater settings. I've already confirmed both the CSM and Monitor 40's can reproduce bass down to 40 Hz as well, so a 50 Hz crossover is not unreasonable.
    The only thing left is to recalibrate the subwoofer to blend in with the CS-G203 front speakers, but that is easily done since I go for the subtle effect of the subwoofer being a natural rolloff from the main speakers.
    Yours may vary, but I don't find tambre matching as valuable as channel volume matching calibration.
    Others may vary in their opinions, of course.
  • Syndil
    Syndil Posts: 1,582
    edited January 2013
    There's a thread on my thoughts about this somewhere... To summarize, I had a non-timbre-matched center with my system, a Polk CS350LS, with Infinity Overture 1 fronts. In order to "correct" this "error", I purchased an Infinity CC-3 center channel, which uses the same drivers as the Overture series. After auditioning the two, I sold the CC-3 and put the CS350LS back into service, as it was obviously the superior-sounding center channel, despite the lack of timbre-matching. Matched or not, it sounded 1000% better.
    So IMO, timbre-matching is not anywhere near as important as having a high-quality center channel. That said, going from a CSi3 to a CS10 seems more like a sideways move than an upgrade, so it may be more a question of "why not." A CS20 might be a slight upgrade.
  • oleon621
    oleon621 Posts: 178
    edited January 2013
    I had a csi5 with tsi400s as my front stage for a while. I was happy with the setup but then eventually came across a good deal on some Rti A7s which timbre match the csi5 and I must say the difference was quite significant to my ears. The front stage just flowed seamlessly with one another. The transitions from left to middle and right just flowed.
    Front- RTI A7,(powered by ADCOM GFA 5500)
    Center- CSI5,
    Surrounds- RTI 6 and Rear Surrounds- TS 15.
    TV-Panasonic P55ST50
    SUB-SVS PB10-NSD and PSW505
    Receiver- Yamaha Aventage RX-A2000
  • Energene
    Energene Posts: 8
    edited January 2013
    I agree with Syndil, I will take quality over timbre matching any day. In my best set up I use an A7 as a center and run it full range large. I do tend to not mix brands or wide range of qualities on fronts/center though, and I have done many setups.
    F1nut Posts: 51,996
    edited January 2013
    Energene wrote: »
    I agree with Syndil
    That doesn't put you in good company as he doesn't have a clue about all things audio.
  • Geoff4rfc
    edited January 2013
    Syndil wrote: »
    High quality components are awesome to have, but IMO, when the sound differs when it travels between the L, C and R channels, it's no longer seamless. That might not be important to some, but I prefer my front stage to have a seamless sound field.
  • Syndil
    Syndil Posts: 1,582
    edited January 2013
    I don't use my center when listening to music, so for me it's not an issue. In my system the center is only used when there is a discreet center channel to be heard. I don't do multi-channel stereo or Pro Logic II or any of that. So really it's just used for dialog, and it doesn't matter if it doesn't match my L/R channels perfectly. It's not contributing to the soundstage produced by the L/R channels, it's interrupting it.
  • Face
    Face Posts: 14,340
    edited January 2013
    Syndil wrote: »
    You shouldn't even respond to this topic.
    F1nut Posts: 51,996
    edited January 2013
    Originally Posted by Syndil
    Blah, blah, blah
    You see Energene, I told you he doesn't have a clue.
  • Syndil
    Syndil Posts: 1,582
    edited January 2013
    Glad to see I can still get a good "harumph" from the old guard any time I post something that does not fit the perceived status quo.
  • falconcry72
    falconcry72 Posts: 3,580
    edited January 2013
    CarlosD wrote: »
    ...The specs on the CSi3 and CS10 are very close...
    The specs mean nothing in terms of timbre and tone matching.
    ...I have a hard time believing that my enjoyment of my system would be worth the extra expense...
    It doesn't have to be an extra expense! Find a used CS20, buy it, and try it in your system. See which center YOU like better, then sell the other one! No expense! (or MINIMAL at most)
    In this hobby, all that matters is how it sounds to YOU, and you won't know that until you try it. 100 different people will give you 100 different opinions. Screw their opinions! Find out for yourself!
  • ntculenuff
    ntculenuff Posts: 1,146
    edited January 2013
    if you can get a center close to your mains it will work. yeah there will be a slight difference mostly not noticeable. I say this cause i had an all polk system when i started sounded great (RT10's, CS350ls, LS f/x's) As i started to upgrade going through the polk line a few times for the mains i had started to really like the definitive technology speakers (you can see my current setup in my signature) For years i used the CS350ls (which by the way is an awesome center) with my definitives (until i finally had the extra cash for my matching center) it worked great with movies, sacd, dvd-a. the only time i could tell a slight difference in the timbre matching was when i would do a pink noise roll through the speakers.
    I would say the biggest problem is when you get a center that is either larger/smaller or completely different than your mains. you get what i always consider the harley-honda-harley effect. as was stated by Geoff4rfc. voices or such going across your front stage being different.
    Well there are many opinions on here already and this one is mine. the one thing i really enjoy about this hobby is that, all the opinions. It is ultimately up to you and your ears, budget and so on. best advice i can give,try to think about the big picture and where you would like to be. don't settle cause it is all you can afford at the time, you will only be temporarily satisfied and wish you had just waited for the extra $$ to get the other one. i have to keep this in mind when i want something new (and you always will) so far it has paid off. Sure i chomp at the bit a lot, it took me 2 years to finally pull the trigger on a receiver to replace my old setup from 2004 (glad i waited too).
    OK sorry, i babbled for long enough...
    On a side note i used the CS350ls for 12 years and sold it for $250. This center channel was truly amazing and was the heart of my speakers, it was my favorite to show off :)
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
    F1nut Posts: 51,996
    edited January 2013
    Syndil wrote: »
    That would be all the time.
  • ntculenuff
    edited January 2013
    ZLTFUL wrote: »
    So what your saying is that your speakers go from being leaky, unreliable 1920s tech to reliable and durable and doing things way better and then back to being leaky and unreliable again?!?!
    :lol:
    Sorry...couldn't help myself. Never bought in to the Harley marketing juggernaught and always enjoy poking them with a stick when I can.
    But that is actually an excellent analogy.
    LOL yeah that. So for you I will re word it Honda-Harley-Honda :biggrin: did find out why they did leak oil though. It was to oil the chain, if there wasn't a dime to quarter size oil drip something was wrong lol. Of course it was a Harley guy that told me :rolleyes:
    Speakers:
    Polk RT800i's rears
    Audio:
    Onkyo TX-NR3010
    Video:
    OPPO BDP-103 Bluray
    Directv x's 2
    edited January 2013
    I don't understand what all the discussion here is about. This is a SIMPLE answer. You want to upgrade your center so as to timbre match the TSI-400s?
    Get the CS20 and call it a day! Stay in the series and ALWAYS get the biggest, baddest center within that series. That's the CS-20 in this case!
    For Rti-As it would be the CSi-A6 or CSi-5 (of older Rtis!).
    cnh
    edited January 2013
    What he said ^^^^
    The center channel in a surround format is the anchor for the whole shebang. Get a good one, or don't use one at all and run phantom. Thats the only 2 options I see.
  • Energene
    Energene Posts: 8
    edited January 2013
    Has anybody used a full range tower as a center like I have?
    I really like it and I am not sure I could go down to a center.
  • BlueFox
    BlueFox Posts: 15,250
    edited January 2013
    While not exactly related to the current discussion, my HT used to consist of 4 LSi15s and an LSiC. While this worked great, I felt there could be more 'oomph' (technical term) from the center. One day I bought a PSB Synchrony One center, and it dropped right in. I ran setup and everything was still calibrated. Anyway, the PSB center with the LSi15s seemed to my ears to work great.
    Later I replaced the front LSi15s with PSB Synchrony One towers, and while it had minimal effect on movie audio, it really improved the music audio in the multi-channel system.
  • Face
    Face Posts: 14,340
    edited January 2013
    Energene wrote: »
    Has anybody used a full range tower as a center like I have? .
    Yes, it's great not having to compromise.
  • pearsall001
    pearsall001 Posts: 5,326
    edited January 2013
    Energene wrote: »
    That is the best way to go for a perfect front stage. The only problem is the space requirements, it's just not feasible for most. If that is the case then just get the matching center in your speaker line for the next best option.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited January 2013
    My own experience started with matching centers, then went thru several different fronts but kept the original center.
    Most of my listening is 2-channel, so I was not as critical of timbre matching (in the beginning) for a center.
    When I did do movie watching or multi-channel listening (mostly for concert videos or cable), I first thought it was good enough.
    But over time I settled into a pair of front speakers I like and kept my eye open for a matching center - when a deal came along, I jumped on it and will have to say that timbre matching is important.
    You can have speakers that don't match and depending on how critical your ear is the sound can be ok to good, but they must all match to get it 'right'.
    However, I will say that my own personal preference for multi-channel music is to pull the center volume down. I've found that when the AVR does its auto-calibration the center volume is too high, imo - the sound is 'mono' with no left/right soundstage separation (for my tastes). So I save two settings: 1 for movies where I let the AVR set the volume levels, 1 for music where I manually lower the center volume to a point where it is filling in the center of the soundstage, but it does not dominate it and destroy L/R imaging.
    In the end - let your ears decide what you like, but keep them open for changes!
  • deronb1
    deronb1 Posts: 5,021
    edited January 2013
    I was skeptical of the whole timbre matching thing at first. I was running a CS400i center with my Def Techs and it really was fine for movies because it is a kick **** center channel speaker. When I found a deal on a Def Tech C/L/R 2002, I snatched it up and replaced the CS400i. At first I wasn't impressed because I was used to the CS400i and how dominant the dialog was with movies, but after a while I started to appreciate the seamless sound.
    Also, if you listen to music in "ext surround" or 5.1, there is a HUGE difference, especially with 5 ch SACD playback. If you are not timbre matched there, IMHO, it will just sound weird. You wouldn't have two different speakers for stereo music listining right? So what makes multi channel any different?
  • Syndil
    Syndil Posts: 1,582
    edited January 2013
    Erik Tracy wrote: »
    You might also try downmixing to quadraphonic for multi-channel music. That way you do not miss out on whatever music is supposed to be coming from the center by turning its volume down, yet you don't sacrifice soundstage separation. This is what I prefer. The center channel was only ever intended to ground dialog to the screen--there's a reason we didn't have a center channel until the home-theater revolution. But quadraphonic music has been around in one form or another since the '50s.
