Cosmetic modding??
snake1
snake1 Posts: 567
edited January 2013 in Speakers
Aside from the idea of women's make-up that comes to mind reading the title :lol: I'm curious about something. I love my 12s but I really like the all black veneer of the A9s especially on the front around the speakers. The silver of the 12s is fine, but that black just looks sweet. Wonder how difficult it would be to paint the fronts to match the sides?? What kind of paint could you use? Anyone with any thoughts or done something like this?
AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it
Post edited by snake1 on
  • ken brydson
    ken brydson Posts: 9,073
    edited January 2013
    There is a thread on where to buy black paint. Look it up....
  • snake1
    snake1 Posts: 567
    edited January 2013
    Well I was hoping for more tips and input than a paint color but I'll look it up.
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • michael1947
    michael1947 Posts: 775
    edited January 2013
    It's not too difficult painting things, just use very good paint...automotive quality. More interestingly though, just last week while ordering stuff from parts express I spied some very nice black vinyl veneer that is self-adhesive. It comes in rolls 2'x8' and looks like it would match the chassis on my old Polk RT 2000p's which need the same "facelift." Good luck, please report back with progress and pictures.:razz:
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
    VR3 Posts: 29,662
    edited January 2013
    My favorite "cheap" finish for a speaker is truck bed liner...
    It gives a nice texture, its durable and its BLACK :)
    It is also easy to apply (roller)
    VR3 Posts: 29,662
    edited January 2013
    I actually just painted a speaker with this - on the final coat I did a 80 grit sand and then painted it black and it turned out awesome!
  • Thorton
    Thorton Posts: 1,324
    edited January 2013
    It all matters of how close of a match your looking for. If you keep the grills off and want a close match, I would pass if I was a novice. If you just want them black then go for it. I haven't refinished speakers but just have about painted everything else. It all comes down to the quality you're looking for. If you want to keep the wood grain appearance, abrade the surface lightly to provide adhesion however don't sand to much too lose the texture. Surface prep is usually critical. Also depending on the paint used and amount that you put down, you can completely lose the texture (wood grain) that is apparent in the wood. A textured bed liner coating will not look like the current paint on the sides and top of the speaker. It does look good if you're not trying to match the rest of the speaker. Matching the gloss level is a whole other ball game. If your hell bent on this I can tell you how to do this. Also, the selection of what kind of paint is determined by what you're looking for.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
