DIY push on/off button
MillerLiteScott
Anybody have a good source for a cool but simple on off button for a DIY amp?
I would like it to be a round brush nickel button with/without a blue light around the button.
I have googled and searched but I have come up empty.
Thanks,
Scott
Thanks,
Scott
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Short answer - no I don't.
Slightly longer answer: Here are two - potentially - good places to look (if you haven't already):
www.allelectronics.com
www.partsconnexion.com
EDIT: Towson, eh? I went to high school in Towson :-)
oh, another potential source - www.tubesandmore.com -
What HS in Towson, what year?
I went to EVT '85.
StanStan
Main 2ch:
HT:
Other stuff:
http://m.radioshack.com/radioshack/product/detail.do?itemId=3125352&categoryId=&cust_categoryId=&path=
I used this switch on my preamp, and it works great and is quite bright; only requires 120v source to power the LEDs which is nice. Black body is not my favorite, but switch is cheap is works well. -
I have one exactly like you are talking about in my DIY DAC, but green instead of blue that I got from mouser. I don't remember the manufacturer, but I'll try to search it out. I bought it over 2 years ago, so I don't know if they still carry it or not. I know it came in blue as well. Let me check and I'll post again if I find it.
Does it need to be single pole or double pole, or what configuration? The one I have is DPDT.
I found these, but they are all SPST. Hopefully one of these works: http://www.mouser.com/Schurter/Electromechanical/Switches/Pushbutton-Switches/_/N-5g30Zscv7?P=1z0z2ttZ1z0z2njZ1z0z24zZ1z0z812Z1z0zpeiZ1z0z2y5Z1z0yt3kZ1z0z810&FS=True
It's similar to the switch I used.
Nope, got it. It's just like this one:http://www.mouser.com/ProductDetail/Schurter/124168341124000/?qs=%2fha2pyFaduh1T%252bfZ%252bEsvksaepf1n9o40vOiCg9ER%252baj%2f1tSZeIKOxSsu7DrTqjuz
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Nope! It's the one in the above post that you want (I believe).
Baltimore Lutheran ahem 1976 :-)What HS in Towson, what year?
I went to EVT '85.
Stan -
Thanks guys!!!!! I will take a look at all of your suggestions.
ScottI like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
Wiring up a touch mount switch would be pretty cool on an amp.
