DIY push on/off button
MillerLiteScott
MillerLiteScott Posts: 2,564
edited January 2013 in DIY, Mods & Tweaks
Anybody have a good source for a cool but simple on off button for a DIY amp?
I would like it to be a round brush nickel button with/without a blue light around the button.
I have googled and searched but I have come up empty.
Thanks,
Scott
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
    mhardy6647 Posts: 35,562
    edited January 2013
    Short answer - no I don't.
    Slightly longer answer: Here are two - potentially - good places to look (if you haven't already):
    www.allelectronics.com
    www.partsconnexion.com
    EDIT: Towson, eh? I went to high school in Towson :-)
    oh, another potential source - www.tubesandmore.com
  • skrol
    skrol Posts: 3,499
    edited January 2013
    What HS in Towson, what year?
    I went to EVT '85.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • zingo
    zingo Posts: 11,258
    edited January 2013
    http://m.radioshack.com/radioshack/product/detail.do?itemId=3125352&categoryId=&cust_categoryId=&path=
    I used this switch on my preamp, and it works great and is quite bright; only requires 120v source to power the LEDs which is nice. Black body is not my favorite, but switch is cheap is works well.
  • headrott
    headrott Posts: 5,496
    edited January 2013
    I have one exactly like you are talking about in my DIY DAC, but green instead of blue that I got from mouser. I don't remember the manufacturer, but I'll try to search it out. I bought it over 2 years ago, so I don't know if they still carry it or not. I know it came in blue as well. Let me check and I'll post again if I find it.
    Does it need to be single pole or double pole, or what configuration? The one I have is DPDT.
    I found these, but they are all SPST. Hopefully one of these works: http://www.mouser.com/Schurter/Electromechanical/Switches/Pushbutton-Switches/_/N-5g30Zscv7?P=1z0z2ttZ1z0z2njZ1z0z24zZ1z0z812Z1z0zpeiZ1z0z2y5Z1z0yt3kZ1z0z810&FS=True
    It's similar to the switch I used.
    Nope, got it. It's just like this one:http://www.mouser.com/ProductDetail/Schurter/124168341124000/?qs=%2fha2pyFaduh1T%252bfZ%252bEsvksaepf1n9o40vOiCg9ER%252baj%2f1tSZeIKOxSsu7DrTqjuz
  • headrott
    edited January 2013
    Nope! It's the one in the above post that you want (I believe).
    edited January 2013
    skrol wrote: »
    I went to EVT '85.
    Stan
    Baltimore Lutheran ahem 1976 :-)
  • MillerLiteScott
    edited January 2013
    Thanks guys!!!!! I will take a look at all of your suggestions.
    Scott
  • cowtrimmer
    cowtrimmer Posts: 201
    edited January 2013
    Wiring up a touch mount switch would be pretty cool on an amp.
