Recommended Subs for LSiM 7.2 setup
sarvic
sarvic Posts: 51
edited January 2013 in Speakers
Just wondering what dual subs you would recommend using with the LSiM speakers. Not sure yet if I'm getting the bookshelf or towers yet. This would be a 7.2 channel config in a 15x21 room with 8' ceiling
Thanks!
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited January 2013
    Budget? We can spend about as much as you can afford - and more! :cheesygrin:
    Use: movies or music? If both what gets more usage?
  • snake1
    snake1 Posts: 567
    edited January 2013
    SVS are good for just about any budget and also have a trade up policy I will be taking advantage of when the time comes.
    AVR - Onkyo NR809
    500gb HD for MP3 and FLAC files
    Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
    Mains - Polk RTi12 towers
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    Movies and games - PS3
    TV - Toshiba 52" HD
    Every vehicle has one good nuetral drop in it
  • toucanet
    toucanet Posts: 581
    edited January 2013
    JL Audio F113 is my recommendation (although budget is unknown).
  • pearsall001
    pearsall001 Posts: 5,400
    edited January 2013
    A nice pair of used Velodyne SPL-1200's would do the job nicely for both HT/2 channel. I'm speaking from experience here!
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited January 2013
    You can get dsw micropro 3000's for 849 on weekends at newegg... I can't imagine you would ever play them at greater than 50% of their gain..They do great on ht applications and are ok for music... They look great
    Garage | Polk Monitor 5B's
  • sarvic
    sarvic Posts: 51
    edited January 2013
    As far as budget, i was thinking along the lines of $800-1000 per subwoofer but it doesn't have to be that much, just something decent quality to evenly fill the bass of the theater room. Was going to put them both up front on near the front right and left speakers. Probably 70% movies, 30% music for now.
  • sarvic
    sarvic Posts: 51
    edited January 2013
    DSkip wrote: »
    Go with the 703's if you're going to get you some nice subs. You'll have the low end covered, and the 703's add a lot more punch to the midbass to liven it up.
    Yeah, the 703's are what i would use unless there would be a good reason for me to justify getting the towers. Pretty big price difference.
  • Erik Tracy
    edited January 2013
    sarvic wrote: »
    Hsu, SVS, was going to also recommend Epik but heard there are some issues there.
    REL is another good one as well as JL.
  • sarvic
    sarvic Posts: 51
    edited January 2013
    These looked pretty nice but wasn't sure if two of them would be overkill:
    http://www.svsound.com/subwoofers/ported-box/pb12-plus
  • Erik Tracy
    edited January 2013
    sarvic wrote: »
    Nice.
    Overkill? Pfffft.
    That would be the definition of 'killer' :cheesygrin:
    txcoastal1 Posts: 13,520
    edited January 2013
    Every knows that pairs are more fun to play with:cheesygrin:
  • michael1947
    michael1947 Posts: 775
    edited January 2013
    I use a pair of Polk Micro-pro subs (8") in my HT system and am satisfied. I also just replaced an older Klipsch 10" sub with a new Polk 505 and like the lower range of the 12" unit. The Polk 505 has had a few bad reviews however for a well powered 12" unit with a warranty it is delivered for only $180. via Amazon. I like a lot of base with my movies so I run 4 smaller subs and now the new 12" Polk 505...when the Navy guys in Battle Ship blow up the Aliens it really rocks the house.:razz: As far as the "expensive" subs go I have shied away from them as I am not totally convince that 1 $1,500 sub sitting in one location can out perform my 4 or 5 sub configuration...just my way of doing things.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2013
    I'm guessing you haven't heard a $1500-$2000 ID sub? Quality>Quantity.
  • blehmbo
    blehmbo Posts: 179
    edited January 2013
    Look into Rythmik's offerings. My F15HP is awesome :smile:
